who repairs door stays? |
rfuerst911sc |
Oct 29 2008, 08:03 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
My drivers side door stay is banging/clicking and I'd like to get this fixed. I thought I read on this forum a while back that someone was repairing these? Car is a 75. Or if you know how to repair can you pass on the secret? Thanks
southernmost914 |
Oct 29 2008, 08:26 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
Just need to replace the roller wheels and control arm( if worn bad). We have a vendor in the Vendor section who sells what you need. Easy job. (IMG:style_emoticons/default/bye1.gif)
Steve |
914Sixer |
Oct 30 2008, 08:29 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Check to see what your roller set up is. You will probably only need the one plastic roller and a new arm. They later door stays had one steel roller that will not need replacing unless it is damaged. When removing and installing the springs use a piece of wire looped through the spring. It will make the install or removal easier
davesprinkle |
Oct 30 2008, 11:08 AM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
I sell a kit of parts to fix the door stay mechanism. Each kit includes two rollers and an aluminum door stay. Pretty easy job.
rfuerst911sc |
Oct 30 2008, 05:19 PM
Man I feel like a dope (IMG:style_emoticons/default/headbang.gif) Before I posted this question I did a search AND looked at the vendors forum and completely missed it!! Thanks everyone for the feedback, I'll be getting in touch with the member vendor to order his kit. (IMG:style_emoticons/default/beerchug.gif)
rfuerst911sc |
Oct 30 2008, 05:31 PM
Lou W |
Oct 30 2008, 07:14 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
Easy fix (IMG:style_emoticons/default/smile.gif) ;
Attached image(s) |
Justinp71 |
Oct 30 2008, 10:23 PM
Senior Member Group: Members Posts: 1,584 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Does anyone know where to get a replacement spring for the door latch (in the door jamb)? Its a really tiny spring, but I'm sure it has to be the exact right one for the door latch to work. |
Joe Owensby |
Nov 1 2008, 06:06 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Popping can be caused by a worn out opening in your door jam, the pivot where the stay goes. If it is worn, it allows the stay to pull to one side, and then pop back to the other when the roller goes over the hump. I don't know of a good fix for this, other than some welding. JoeO
Joe Owensby |
Nov 1 2008, 06:08 PM
Sorry, double post. I can't find how to erase it though.
Lo-Fi Version | Time is now: 11th June 2024 - 10:07 AM |
