Outer window fuzzy - removal, easy way to do it??? |
EJP914 |
Nov 16 2008, 09:33 AM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Outer window fuzzys have dry rotted and falling out of the track. Is there an easy way to remove them without taking the window out of the door? I think if I can get the window low enough in the door I should be able to get to the 3 screws that hold the fuzzys in place. I see there is a 13mm bolt that goes thru a white plastic block that I think holds the window to the up/down mechanism. IF I take this bolt out, will it allow the 2 arms to come out of the track and let the window drop? I didn't want to take the entire chrome window pillar, door glass, and vent glass all apart since it is adjusted very well with no gaps or leaks. BTW, car is '74.
I guess there is no way to just slide the new fuzzys into the track from the end of the door? That would be too easy! Appreciate the suggestions. |
southernmost914 |
Nov 16 2008, 11:26 AM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
Outer window fuzzys have dry rotted and falling out of the track. Is there an easy way to remove them without taking the window out of the door? I think if I can get the window low enough in the door I should be able to get to the 3 screws that hold the fuzzys in place. I see there is a 13mm bolt that goes thru a white plastic block that I think holds the window to the up/down mechanism. IF I take this bolt out, will it allow the 2 arms to come out of the track and let the window drop? I didn't want to take the entire chrome window pillar, door glass, and vent glass all apart since it is adjusted very well with no gaps or leaks. BTW, car is '74. I guess there is no way to just slide the new fuzzys into the track from the end of the door? That would be too easy! Appreciate the suggestions. I had to remove the chrome 'A'pilar frame and glass and remove the window off the track. Take your time working the new fuzzy on. It's not a easy job. (IMG:style_emoticons/default/bye1.gif) Maybe this will help:http://www.914world.com/bbs2/index.php?showtopic=88650&st=20 Steve |
markb |
Nov 16 2008, 10:28 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Window has to come out. (IMG:style_emoticons/default/sad.gif)
Lo-Fi Version | Time is now: 7th June 2024 - 12:15 AM |
