Old Mallory Unilite Question |
yeahmag |
Nov 18 2008, 04:38 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I have an old Mallory Unilite Distributor (I believe it's the YL advance if memory serves...) that I have cleaned up, lubed, and matched to the grey-grey advance curve of the new distributors (green/purple in my case) and locked at 16 degrees of total advance.
I flipped it upside down to fill the oiling hole with some oil and as I spun it I noticed the shaft moved up enough to allow the advance plate to lightly scrape the bottom of the Unilite mounting plate. Is this normal? If not, should I shim the securing E-Clip inside with a bigger washer or add a small shim to the bottom of the distributor just above the drive gear? Thanks. -Aaron |
yeahmag |
Nov 20 2008, 04:41 PM
This is some great info:
http://www.shoptalkforums.com/viewtopic.php?t=117899 |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:21 PM |
