Timing hole plug, Why don't it fit? |
BiG bOgGs |
Nov 21 2008, 09:24 AM
The Bogus One Group: Members Posts: 452 Joined: 25-September 04 From: Ft. Myers, FL 33967 Member No.: 2,829 Region Association: South East States |
I bought a timing hole plug a while back, it has the right part number (021 119 233 A), but it keeps getting blown out of the hole. I can ALMOST just put it right in without having to screw it at all. And the threads on both the plug and the fan shroud look fine. Is there a different part number for the plug on a 76 2.0L?
Jim |
dr914@autoatlanta.com |
Nov 21 2008, 10:07 AM
914 Guru Group: Members Posts: 7,869 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I bought a timing hole plug a while back, it has the right part number (021 119 233 A), but it keeps getting blown out of the hole. I can ALMOST just put it right in without having to screw it at all. And the threads on both the plug and the fan shroud look fine. Is there a different part number for the plug on a 76 2.0L? Jim strange. they should all be the same! Is it one of those repros from automobile atlanta? |
So.Cal.914 |
BiG bOgGs |
Nov 21 2008, 10:10 AM
Hi Doc!
No, it is not reproduction, just a used one I picked up. It looks like a slightly abused brother to the one pictured in your catalog. |
BiG bOgGs |
Nov 21 2008, 10:14 AM
Actually, now that I look closely at the one in your catalog and the one I have, they both have the same flat spot on the right finger grip as pictured in the AA catalog. So I don't know if it is an original, or if it is a used repro.
So.Cal.914 |
Nov 21 2008, 10:48 AM
The one on mine is so freaking tight I need to use plyers to unscrew it.
r_towle |
Nov 21 2008, 12:17 PM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Actually, now that I look closely at the one in your catalog and the one I have, they both have the same flat spot on the right finger grip as pictured in the AA catalog. So I don't know if it is an original, or if it is a used repro. Dunk it in liquid enlarging cream...careful to wear gloves and dont rub anything else. Attached image(s) |
BiG bOgGs |
Nov 21 2008, 12:39 PM
The one on mine is so freaking tight I need to use plyers to unscrew it. Up for a trade? (IMG:style_emoticons/default/rolleyes.gif) |
Drums66 |
Nov 21 2008, 12:47 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif)
Actually, now that I look closely at the one in your catalog and the one I have, they both have the same flat spot on the right finger grip as pictured in the AA catalog. So I don't know if it is an original, or if it is a used repro. Dunk it in liquid enlarging cream...careful to wear gloves and dont rub anything else. (IMG:style_emoticons/default/av-943.gif) |
BiG bOgGs |
Nov 21 2008, 01:37 PM
Actually, now that I look closely at the one in your catalog and the one I have, they both have the same flat spot on the right finger grip as pictured in the AA catalog. So I don't know if it is an original, or if it is a used repro. Dunk it in liquid enlarging cream...careful to wear gloves and dont rub anything else. My wife is interested in the cream method. I've never seen her this interested in my car. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:47 AM |
