What size rims will I need to buy..., For my 914-6 GT conversion |
futuresoptions |
Nov 23 2008, 12:42 PM
Happy Camper Group: Members Posts: 55 Joined: 14-November 08 From: Tejas Member No.: 9,757 Region Association: None |
Thanks for all the help yesterday with my suspension question guys! (IMG:style_emoticons/default/pray.gif)
I pretty much was able to fill in the rest of my build sheet on my own, but the last item that I need to fill in I know nothing about... I want to use the black centered 5-lug SC Fuchs on my car but don't know what size I will need. I am planning on purchasing the steel flares from AA, and I would like to use 16" Fuchs, What I would like to know is... What size width front rim to buy... Whar size width rear rim to buy... I prefer to not use spacers if I can get away with it, but I would like to fill in the flares. I also would prefer not to deal with any clearance issues from going too wide.... Would like to know what is common... and what works well.... Thanks in advance... |
pete-stevers |
Nov 23 2008, 12:51 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
i will be running 16x 7s and 8s with my flares
225s up front and 245s in the back but i may need to space a bit with the 7s up front... but you could go 8s all around |
Eric_Shea |
Nov 23 2008, 01:31 PM
PMB Performance Group: Admin Posts: 19,275 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Depends on how accurate you want to be with the GT thing.
7&8x15 would be spot on. It's harder to find big rubber for 15's though. 7&8x16 would work. One thing to consider is offset. A 911 8" will fit nicely in the rear. I believe a 944 8" will require some spacers. Spacers are "generally" required up front unless you get 8's there as well. The factory GT parts book has a few spacers listed. |
futuresoptions |
Nov 23 2008, 01:44 PM
Thanks very much guys!!!
burton73 |
Nov 23 2008, 06:05 PM
burton73 Group: Members Posts: 3,530 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I have bought 911 turbo 8" and 9" for the front and rears so I should not need spacers. This is from 2 different sets. One set was 6” and 8” from a special edition 911, and I bought a set of 7” and 9” from a 911 Turbo. I ended up with a few extra wheels that I will sell some time. You will need to spend some time looking for these if you go with the real Fuchs as there pricing has been going up for the last few years. Cash is king thought now so it is hard to tell what you will need to pay.
Have your wheels or at least a 7” to fit your flares to the body when you put them on, as each car is a little different. I used an 8” to center the flares over the tire. Bob |
Lo-Fi Version | Time is now: 23rd May 2024 - 05:16 PM |
