Which one do i buy?, From weber carbs direct |
turnaround89 |
Nov 24 2008, 05:51 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I am looking to buy the dual weber carbs conversion kit from weber carbs direct and wanted to know which one i need to buy. I want the 40idf carbs but there are three different choices on the website
http://www.webercarbsdirect.com/Weber_Carb...hicles_s/38.htm Which one out of the three choices do i buy?, i have a 1.8L engine in a 1972, but tone of the choices is for a 2.0L 73-76, do i just buy that one or one of the others? The other two choices are for 356's or 912's! Thanks everybody! |
r_towle |
Nov 24 2008, 06:01 PM
Custom Member Group: Members Posts: 24,579 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
WK288
Rich |
904svo |
Nov 24 2008, 06:50 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
The new Weber are junk!! Ask Jake. I would buy EMPI version of the carbs.
My own $.02 Check this out. http://forums.aircooledtechnology.com/show...ight=empi+carbs |
SGB |
Nov 24 2008, 07:22 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
The short intake manifolds shown in those kits leave a lot of torque unrealized...
turnaround89 |
Nov 24 2008, 08:09 PM
I can't get onto the website you listed 904svo, i can't even register so i can't do any of the reading.
I was always told to not buy empi stuff, its supposed to be bad quality. If not those kits where should i buy from? I have a single carb now and throttle response is horrible, if you stomp on the gas, the engine almost dies, you have to ease on the gas to get the car to not die. Coming out of corners isn't that much fun when you have to ease on the gas. Im not saying im flooring it out of corners, but it would be nice to hit the gas and actually go and not have the engine almost die. |
scotty b |
Nov 24 2008, 08:14 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
The new Weber are junk!! Ask Jake. I would buy EMPI version of the carbs. My own $.02 Check this out. http://forums.aircooledtechnology.com/show...ight=empi+carbs (IMG:style_emoticons/default/agree.gif) Empi carbs but find a set of better manifolds. Empis manifolds are shit.Carbs worked great right out of the box though. My thread on a customers car http://www.914world.com/bbs2/index.php?sho...mp;hl=Empi+carb |
904svo |
Nov 24 2008, 08:32 PM
turnaround89 |
Nov 24 2008, 09:22 PM
What does CS mean?
Also, it says to buy a dual weber 40idf or the empi kit so which one is it. If i buy the empi kit do i need new intakes, it seems like i will need that for the weber kit as well? Thanks everybody!! |
turnaround89 |
Nov 25 2008, 01:02 PM
Found a website thats sells the empi kit actionimport.com
I think the last one on this page is the one i am going to buy. Looks like a good deal, lots cheaper than weber carbs for sure. Just making sure i get the correct kit. Empi Carb Kit I Want To Buy The last one on the page is the one i am going to order, is it the correct one? Part number is 47-7347 |
Gint |
Nov 25 2008, 02:31 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
What does CS mean? Also, it says to buy a dual weber 40idf or the empi kit so which one is it. If i buy the empi kit do i need new intakes, it seems like i will need that for the weber kit as well? Thanks everybody!! CS refers to Jake's "Camper Special" engine kit/build for a VW Bus. You're obviously not building one of those. That thread is on Jake's sote and is a recommendation to an entirely different scenario, but your question is similar (but yet not the same). Or means either. The 47-7347 is the correct Empi kit for a 2.0 liter Type IV motor. |
turnaround89 |
Nov 25 2008, 03:03 PM
I take it the kit won't work for a 1.8L, will it, aren't the heads different making the intakes not fit correctly? Anyone know where to get dual carbs for a 1.8L?
ONTHEGRIND |
Nov 26 2008, 12:56 PM
Member Group: Members Posts: 286 Joined: 10-November 08 From: California Member No.: 9,738 Region Association: None |
You can read here..
http://www.tunacan.net/t4/tour/heads.shtml there is a good article on cylinder head castings I belive theys have the same intake bolt patterns.. here is one on carbs.. http://www.tunacan.net/t4/tech/intake.htm I am going to pick up a 1.8 to start my build with from what I have read the 1.8 heads seem to be a better heads. well for my app atleast as I am going to get new seats valves and guides and do some port work. I will be using dellorto 45's prepared by http://www.aircooledengineering.com/ I already have the manifolds ported and coated you can probably call ace and get a carb from them.. My 100 dollar dells (IMG:http://img.photobucket.com/albums/v236/xr8ted/100_2022.jpg) |
Lo-Fi Version | Time is now: 23rd May 2024 - 05:00 PM |
