Battery / Starter Questions |
NineOneFour |
Dec 6 2008, 11:44 AM
Member Group: Members Posts: 53 Joined: 3-February 08 From: Los Angeles Member No.: 8,662 Region Association: Southern California |
I have a question for all of you high compression kinda guys. I recently installed a 2056 that has a compression ratio of 9.5 to 1. The stock starter wasn't up to the job, so I installed a high torque mini starter http://www.automotion.com/productpage.aspx...&pid=103294 and a light weight racing battery http://store.summitracing.com/partdetail.a...mp;autoview=sku. I choose this battery because it was the same size as the battery that was in the car when I bought it, but had more cranking amps. The old battery/starter worked fine until I rebuilt the engine.
I now know that the new battery isn't up to the job either so my first question is what type of battery should I be running and how many cold cranking amps are necessary to ensure a reliable start every time? The car came without a battery tray in the engine compartment, the currant battery is installed in the cabin, but I'm thinking about mounting the battery in the front compartment so size isn't an issue. Question number 2: The starter is not working like it did when I first purchased it. It's cranking slow even if I hook up the battery from my Mustang to it. Could there be something else wrong besides the obvious? Is this starter sufficient? It's still under warranty... Thanks for your help, Rodger |
Dr. Roger |
Dec 6 2008, 02:49 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
ummm....
try removing your ground strap from the transaxle to the body, cleaning contact surfaces with sandpaper, and reinstalling. if hooking up a stronger battery doesn't "fix" your supposed weak battery, then isn't it safe to conclude it isn't a battery problem? New starters usually don't wear out in a short amount of time. So what else can it be??? (IMG:style_emoticons/default/confused24.gif) probably a ground issue. |
markb |
Dec 6 2008, 10:58 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Yup, probably bad grounds.
Lo-Fi Version | Time is now: 23rd May 2024 - 08:04 AM |
