Stock front anti-roll bar question, How do I remove it? |
URY914 |
Dec 6 2008, 08:21 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,091 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I'm trying to get a factory front sway/anti-roll bar off a parts car. The rubber bushing is smaller than the end of the bar. So I can't slide it off the bar to pull the bar thru the body.
Do I need to remove the bushing from the mounting flange before pulling it over the end of the bar? Or just get a bigger hammer? Is it even worth getting it off and selling it? Attached image(s) |
914Sixer |
Dec 6 2008, 08:28 PM
914 Guru Group: Members Posts: 8,908 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Push the bar all the way to one side of the car. Take a screwdriver, needle nose pliers or what ever else you can get the there to pry out the bushing from the backside. They are not the easiest thing to remove. If you use silicone spay it may or may not help.
URY914 |
Dec 6 2008, 08:33 PM
I was about to do that but I was afraid I'd tear it up. I better soak it in WD40 real good.
markb |
Dec 6 2008, 10:11 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Wouldn't you want to put in new bushings if you install it in another car? Then why worry about tearing it up when you pull it out?
Of course my way of thinking is brute force and ignorance, so what do I know? (IMG:style_emoticons/default/biggrin.gif) |
URY914 |
Dec 6 2008, 10:16 PM
Where do I find new bushings?
markb |
Dec 6 2008, 10:19 PM
I'm pretty sure I can get them for you. I can't check for sure until Monday, tho, so it may not do you any good at the moment.
URY914 |
Dec 6 2008, 11:19 PM
I can wait til Monday
Bleyseng |
Dec 6 2008, 11:31 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Paul, use a (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/ar15.gif) to get them off.
later you'll figure out a easier way (IMG:style_emoticons/default/chair.gif) |
914Sixer |
Dec 7 2008, 08:07 AM
New bushings are a must anyway. They are about $15 each depending on where you get them.
URY914 |
Dec 7 2008, 08:33 AM
I didn't realize they were available.
Learn sumpin new aready |
Dave_Darling |
Dec 7 2008, 11:48 AM
Just pry the metal cover off the bushing. You should be able to pull the bushing off the end of the bar at that point, and if you can't--just cut the bushing and replace it later.
--DD |
Eric_Shea |
Dec 7 2008, 07:39 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE just cut the bushing and replace it later (IMG:style_emoticons/default/agree.gif) with his Dampness. |
Lo-Fi Version | Time is now: 12th June 2024 - 06:17 PM |
