correct dust shield (boot) for rear 911 M caliper |
Wes V |
Dec 24 2008, 08:33 PM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
I'm re-building a set of rear 911 "M" calipers and need some information on fitment of the dust shield (boot). I'm trying to get the correct ones.I don't have the originals to look at (PO took them off).
What should the seal, seal against? (IMG:http://www.performanceforum.com/wesvann/914a/dust-seal.jpg) The dust shield shown is from the FAG kit numbered RKS3801 and it is loose around the bore of the piston, where the yellow arrows are pointing. When installed (and the piston is at the bottom of the bore), it appears to seal against the surface pointed to by the blue arrow. The piston is one from Zim's and is dimensionally the same as the original. Wes Vann |
Ericv1 |
Dec 25 2008, 10:22 AM
Member Group: Members Posts: 259 Joined: 30-December 07 From: Cincinnati, Ohio Member No.: 8,518 Region Association: Upper MidWest |
I'm re-building a set of rear 911 "M" calipers and need some information on fitment of the dust shield (boot). I'm trying to get the correct ones.I don't have the originals to look at (PO took them off). What should the seal, seal against? (IMG:http://www.performanceforum.com/wesvann/914a/dust-seal.jpg) The dust shield shown is from the FAG kit numbered RKS3801 and it is loose around the bore of the piston, where the yellow arrows are pointing. When installed (and the piston is at the bottom of the bore), it appears to seal against the surface pointed to by the blue arrow. The piston is one from Zim's and is dimensionally the same as the original. Wes Vann I just rebuilt a pair a short while ago. The boot should seal around the bore of the piston (yellow arrows). I got my replacement kits from pelican and they were fine. Eric |
Wes V |
Dec 25 2008, 03:46 PM
I just rebuilt a pair a short while ago. The boot should seal around the bore of the piston (yellow arrows). I got my replacement kits from pelican and they were fine. Eric The kit I've got, that fits loose on the bore, was purchased from Pelican. Once seeing how it fit, I called Zim's and ordered the kit for the pistons I had purchased from them. That kit is a Porsche factory kit number 901.352.964.11 and it appears to be for a different size piston. (35mm?) Although I could stretch the seal to fit around the piston, it wouldn't fit the caliper body. Wes |
Lo-Fi Version | Time is now: 10th June 2024 - 06:19 PM |
