Going to the track, makin' a list |
seanery |
Feb 16 2004, 06:52 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I'm taking whitey to the track in April. I need to do a couple things, so I'm making a list. I may need a bit of advice on some items.
TO DO LIST Install Front Swaybar Install Rear Bar New Brake Pads (I've used Hawks before, but not on stock brakes) - Recomendations accepted here but remember this may be the only track event for this car, so a good street/track combo pad is what I want. Replace Brake Fluid Clean Air Filters I think that about does it. (IMG:style_emoticons/default/w00t.gif) |
ChrisReale |
Feb 16 2004, 06:55 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
Closer to the event, make sure the wheel bearings are properly adjusted (fronts that is)
Id say do a maintenence job, like oil, valves etc... |
drew365 |
Feb 16 2004, 07:06 PM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
(IMG:style_emoticons/default/agree.gif) I'd say most cars flunk tech because of wheel bearings and batteries not secure enough.
I like to get under the car with all my open ends and tighten everything I can see. You'd be surprised what will work loose when you start putting the car under pressure. |
seanery |
Feb 16 2004, 08:09 PM
bearings are good and valve adjustment has about 200 miles on it.
Oil change was done with valves. |
URY914 |
Feb 16 2004, 08:12 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,967 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Check EVERY f---ing nut and bolt. More than once.
(I lost a rear wheel once at Sebring, my fault (IMG:style_emoticons/default/blink.gif) ) Paul |
seanery |
Feb 18 2004, 12:24 PM
Not to be outdone by Chris & Rich I got my Mod 07 today. It will end up in blue car but I think I'll put it in whitey for the DE in April. Is there a trick to get the horn button to stay in?
I'm looking for a couple items, too. A used 914 Harness bar A momo hub for a '72, can be used and not so pretty as it will only be used until blue car gets here. thanks. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:27 PM |
