need some incite with 5 lug rear hubs, re-installing the hub ?? |
drive-ability |
Dec 29 2008, 01:23 PM
Senior Member Group: Members Posts: 1,169 Joined: 18-March 05 From: Orange County, California Member No.: 3,782 |
so I have a V-8 car with Carrera brakes, rotors and hubs (?).
I removed the hubs, having to wiggle them off with some force. The bearing race seems to have a lip which is giving me trouble putting things together. The bearing race is on the rotor side and the balls are still in the hub.. Before I destroy (IMG:style_emoticons/default/smash.gif) something I thought it a good idea to ask for HELP! |
drive-ability |
Dec 29 2008, 03:32 PM
well after a cup of coffee I pulled the bearing race off the rotor side. I assume I need to replace the bearing. I also assume I need to draw it in slowly...
Now to find the bearings. (IMG:style_emoticons/default/drunk.gif) |
Jeffs9146 |
Dec 29 2008, 04:49 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Yes and Yes!!
The bearing should be replaced and cool it when you mount it into the trailing arm and let it warm up before installing the "cold" hubs. |
drive-ability |
Dec 29 2008, 08:29 PM
Hey,
This looks like the bearing, what do you all think ????????? (IMG:style_emoticons/default/smash.gif) 999-053-020-01-M34 Rear Wheel Bearing, 911 (1974-89) Brand: FAG |
pete-stevers |
Dec 29 2008, 08:40 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
incite.... (IMG:style_emoticons/default/poke.gif) or insight...
jaxdream |
Dec 29 2008, 09:04 PM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Fag number on the inside race 545495AD box says SAaB 900 81/ also outside of box says ( yes boxes talk to me ! ) 9104209 also have a Federal Mogul / BCA set box labeled 513106 , strangely enough the Federal box has a FAG with the aforementioned FAG number. These are for all 914 4 and 914 6 , as well as early 911 with steel trailing arms . ehat you quoted for the 74-89 is the aluminum arm version which uses a wider bearing and would not be suitable for a 914 arm ( severe modification needed ) check around, some of the guys here may have a set for sale, I personnaly am going to keep mine for my 5 lug swap . And yes slowly !!!Good luck !!!!! Jaxdream |
drive-ability |
Dec 29 2008, 09:51 PM
I do have a bit of a Hybrid, l have a 930 trans set-up with Carrera brakes and I think the hub as well.
The bearing dimensions are outside diameter 80 mm, inside is 42 mm, width of housing is 42 mm. There are 2 cages of ball bearings. |
Jeffs9146 |
Dec 30 2008, 01:03 PM
Unless someone cut off the bearing races and welded on late 911 or 944 races (seen it done) then I would still guess it is a 914 part!
drive-ability |
Dec 30 2008, 09:36 PM
I sent a pic and the measurements to Jason at Pelican,
he said this is the part number. 999-053-020-01 The control arms have been modified. (IMG:style_emoticons/default/welder.gif) |
Jeffs9146 |
Dec 30 2008, 09:40 PM
You should post a photo here so we can be enlightened!
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) |
drive-ability |
Dec 30 2008, 11:30 PM
r_towle |
Dec 30 2008, 11:34 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Insight
Lo-Fi Version | Time is now: 11th June 2024 - 07:08 AM |
