Ah Mother #*$&%^, Ummm.... so can you put new bolts in the bumper rubber? |
PeeGreen 914 |
Jan 27 2009, 01:22 AM
Okay. I am not totally screwed yet but just a few minutes ago I was going to take the rubber tops off my bumper and the first nut I tried to get off broke the bolt. Is there a way to remove the stud and redo these? (IMG:style_emoticons/default/confused24.gif)
VaccaRabite |
Jan 27 2009, 06:00 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Cut the bolt flush, drill it out, and glue in a new one with rubber epoxy.
Use antiseize on everything at reassembly. Zach |
So.Cal.914 |
Jan 27 2009, 07:36 AM
Good Answer.
jd74914 |
Jan 27 2009, 07:46 AM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I welded mine back on. You do have to go very slowly to prevent thermal build-up.
Root_Werks |
Jan 27 2009, 08:46 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Weld it, I've done it before. Jon, just bring it over and we'll get it done. Got plenty of 6x1.0 studs floating around anyway. (IMG:style_emoticons/default/wink.gif)
IronHillRestorations |
Jan 27 2009, 10:30 AM
I. I. R. C. Group: Members Posts: 6,730 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Probably not the concours correct solution, but many years ago I just added holes in the top of the bumper, drilled pilot holes into the metal core, and used some sheet metal screws. The bumper top was pretty wavy though, so the core was known to be a little corroded. Held up for a long time though.
This is where a spot welder, or carbon arc torch briefly touched to the attachment nuts can do wonders. Heats up the fastener without transfering too much heat to the rubber. PB Blaster, time, and gentle knudging?? |
underthetire |
Jan 27 2009, 01:54 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Just did mine this weekend. Drilled out old studs and used self tapping sheet metal screws witht the same size hex head as the nuts. Worked fine.
PeeGreen 914 |
Jan 27 2009, 01:57 PM
Thanks Dan. I will be bringing this to you (IMG:style_emoticons/default/biggrin.gif)
Drilling through this top isn't a good idea as it looks perfect. |
Solo914 |
Jan 27 2009, 04:38 PM
Member Group: Members Posts: 266 Joined: 6-March 06 From: Redmond, WA Member No.: 5,678 Region Association: None |
Thanks Dan. I will be bringing this to you (IMG:style_emoticons/default/biggrin.gif) Drilling through this top isn't a good idea as it looks perfect. Man everyone is going easy on you. I would have told you that you are screwed and that you should give up, buy a new one and give me your "garbage" one. (IMG:style_emoticons/default/biggrin.gif) Looks like Dan will get you taken care of. Your bumper tops are some of the nicest I have seen. kyle |
pete-stevers |
Jan 27 2009, 05:11 PM
saved from fire! Group: Members Posts: 2,642 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
save yourself the hassel and get a glass one....
then you have the hassel of fitting the glass... |
PeeGreen 914 |
Jan 27 2009, 05:39 PM
Thanks Dan. I will be bringing this to you (IMG:style_emoticons/default/biggrin.gif) Drilling through this top isn't a good idea as it looks perfect. Man everyone is going easy on you. I would have told you that you are screwed and that you should give up, buy a new one and give me your "garbage" one. (IMG:style_emoticons/default/biggrin.gif) Looks like Dan will get you taken care of. Your bumper tops are some of the nicest I have seen. kyle Thanks Kyle The front has a little pit in on one spot but other than that it looks good. |
degreeoff |
Jan 27 2009, 05:44 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
Thanks Dan. I will be bringing this to you (IMG:style_emoticons/default/biggrin.gif) Drilling through this top isn't a good idea as it looks perfect. Man everyone is going easy on you. I would have told you that you are screwed and that you should give up, buy a new one and give me your "garbage" one. (IMG:style_emoticons/default/biggrin.gif) Looks like Dan will get you taken care of. Your bumper tops are some of the nicest I have seen. kyle (IMG:style_emoticons/default/agree.gif) I was goina say just get a FG bumper and be done with it....hell save a few lbs too (IMG:style_emoticons/default/happy11.gif) |
PeeGreen 914 |
Jan 27 2009, 05:48 PM
I preffer having the metal bumpers. (IMG:style_emoticons/default/beerchug.gif) unless I went Sheridan (IMG:style_emoticons/default/piratenanner.gif)
t collins |
Jan 27 2009, 06:51 PM
Advanced Member Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None |
Just like Zach, I cut it off flush and drilled it out but then I taped it and screwed in a stud locking it in place with Permatex permanent thread lock. Good as new.
Joe Bob |
Jan 27 2009, 07:11 PM
Use a GOOD lubricant....I'm not going to get into the MY ShIt versus Yer CrAp wars....but the technique is important.
TIGHTEN it first, AFTER soaking overnight.....then slowly back it off. If ANY resistance give it another soak....wait another day. Then do the same...if it breaks....have a drink or a smoke....you were screwed from the beginning. As to broken studs, they can be drilled up and a self tapping hex head can be used.....but it's better to try to save them..... |
Root_Werks |
Jan 27 2009, 11:00 PM
I have class Saturday but if you're up for it, bring the pad and bumper over Sunday. I'll call ya. (IMG:style_emoticons/default/wink.gif)
PeeGreen 914 |
Jan 27 2009, 11:40 PM
Lo-Fi Version | Time is now: 8th June 2024 - 05:02 PM |
