VDO Fuel Tank Sender, Wiring |
nigolusa |
Jan 28 2009, 01:09 AM
nigolusa Group: Retired Members Posts: 157 Joined: 10-November 08 From: los angeles Member No.: 9,737 Region Association: Southern California |
Where do the black, Green and brown wires attach? (IMG:style_emoticons/default/ar15.gif)
Dave_Darling |
Jan 28 2009, 09:50 AM
That lower symbol is a ground symbol. In our cars, brown is always ground. Brown goes there.
The "W" should be for the light. That's the black wire. That leaves "G" for the gauge, and the green wire. --DD |
nigolusa |
Jan 28 2009, 03:26 PM
Thank you!!! Now how do I open the trunk with lost key?
That lower symbol is a ground symbol. In our cars, brown is always ground. Brown goes there. The "W" should be for the light. That's the black wire. That leaves "G" for the gauge, and the green wire. --DD |
southernmost914 |
Jan 28 2009, 04:17 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
[quote name='nigolusa' date='Jan 28 2009, 04:26 PM' post='1127086']
Thank you!!! Now how do I open the trunk with lost key? Front or rear? (IMG:style_emoticons/default/confused24.gif) Steve |
nigolusa |
Jan 28 2009, 06:17 PM
Rear. I inherited the car. All keys missing. Can't open the trunk where the targa top gets stored. (IMG:style_emoticons/default/KMA.gif)
[quote name='southernmost914' date='Jan 28 2009, 02:17 PM' post='1127098'] [quote name='nigolusa' date='Jan 28 2009, 04:26 PM' post='1127086'] Thank you!!! Now how do I open the trunk with lost key? Front or rear? (IMG:style_emoticons/default/confused24.gif) Steve [/quote] |
southernmost914 |
Jan 28 2009, 07:19 PM
Work through the engine bay. Push out (into the trunk) the the two plastic cups where the targa top latches sit when stored. Flashlight through one cup hole to see the (2) 10mm latch bolts. All the socket wrench extendtions you can find to feed through the other cup hole. Frustrating but can be done or (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/smash.gif)
Steve (IMG:style_emoticons/default/biggrin.gif) |
nigolusa |
Jan 29 2009, 12:08 AM
WOWO brilliant!!!! will try
Work through the engine bay. Push out (into the trunk) the the two plastic cups where the targa top latches sit when stored. Flashlight through one cup hole to see the (2) 10mm latch bolts. All the socket wrench extendtions you can find to feed through the other cup hole. Frustrating but can be done or (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/smash.gif) Steve (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 03:51 PM |
