Momo wheel on a '71 steering column. Help?, Help? |
fasthonda |
Jan 29 2009, 07:48 PM
914 Type R Group: Members Posts: 133 Joined: 10-January 04 From: Greenville, SC Member No.: 1,544 Region Association: None |
I would like to put a Momo on my '71. Apparently they no longer make the momo Hub (part# 8000) for the 70~71 914-4. What are my options? Can anyone confirm if a 72~76 steering column will fit on the early cars (I realize the electrical connections won't match). Any other options?
Thanks in advance for any info. Michael |
jmmotorsports |
Jan 29 2009, 08:03 PM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
I would like to put a Momo on my '71. Apparently they no longer make the momo Hub (part# 8000) for the 70~71 914-4. What are my options? Can anyone confirm if a 72~76 steering column will fit on the early cars (I realize the electrical connections won't match). Any other options? Thanks in advance for any info. Michael I went through this with my 70, the best option is to use a Dino hub and wheel. I bought the hub from AutoAtlanta and the wheel on ebay. Jerry |
SirAndy |
Jan 29 2009, 09:12 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can anyone confirm if a 72~76 steering column will fit on the early cars (I realize the electrical connections won't match). You can, but it's a MAJOR "Pain In The Ass" (IMG:style_emoticons/default/rolleyes.gif) There are a few threads about that floating around here. I've done it once (mounted a '74 column in a '70 car) ... (IMG:style_emoticons/default/barf.gif) Andy |
justme |
Jan 29 2009, 09:50 PM
Member Group: Members Posts: 187 Joined: 1-January 07 From: southampton ma atlantic northeast Member No.: 7,413 Region Association: North East States |
I would like to put a Momo on my '71. Apparently they no longer make the momo Hub (part# 8000) for the 70~71 914-4. What are my options? Can anyone confirm if a 72~76 steering column will fit on the early cars (I realize the electrical connections won't match). Any other options? Thanks in advance for any info. Michael Hi Michael, I believe you can get one on ebay for $72, shipped Do a search under 914 momo, I think they have both pre & post 71 hubs Cheers |
underthetire |
Jan 29 2009, 10:54 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I actually drilled the hub out of my stock steering wheel and made an adapter to space it forward. But then again I have access to a lot of machine shops. Was able to use my stock horn plate and cancel ring and everything. easy piece to make.
jmmotorsports |
Jan 30 2009, 07:10 AM
I would like to put a Momo on my '71. Apparently they no longer make the momo Hub (part# 8000) for the 70~71 914-4. What are my options? Can anyone confirm if a 72~76 steering column will fit on the early cars (I realize the electrical connections won't match). Any other options? Thanks in advance for any info. Michael Hi Michael, I believe you can get one on ebay for $72, shipped Do a search under 914 momo, I think they have both pre & post 71 hubs The 70-71 Momo hubs on Ebay are for the 914-6. Will not work on a 4. As far as I know Momo no longer makes a hub for the 70-71 4's. Jerry |
Lo-Fi Version | Time is now: 1st June 2024 - 10:16 PM |
