M.S.D Box, good or bad |
6freak |
Feb 5 2009, 01:50 PM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
I have one in the shop..the ? is is it worth the effort to install ,where the best place,and is it hard to do ..mind you I`m electrically challenged so be gental |
ConeDodger |
Feb 5 2009, 02:24 PM
Apex killer! Group: Members Posts: 23,618 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I have one in my 914 and my 240Z. If you have it, I would go ahead and use it. Jake Raby doesn't like them and uses Mallory ignition boxes on carb cars He has had failures and he just doesn't tolerate failure. I think he would even say to use it since you have it though...
jt914-6 |
Feb 5 2009, 02:39 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
I've used a MSD for years and like it. Some will say they like them and some will not. I use a 6AL. It has an adjustable rpm chip slot. A chip kit for example goes from 6,000 to 7,000 in increments of 200 rpm. (6,000, 6,200, 6,400 and so on).
It gets an incoming signal from the points or electronic pickup, depending on which dist. you have. Two wires go to the coil. It is easy to connect and mount. I mounted it in the engine compartment on my last 914-6. On my current project six, I'm mounting it behind the passenger's seat as seen in the pic. I would suggest if you use one that you match it with the MSD Blaster coil, use 7 or 8mm wires, and gap the plugs to 32-36 range. You may have to also use one of their tach adaptor. If you are using a points type dist., you may want to use a Petronix Ignitor or other electronic points replacing device. Attached image(s) |
6freak |
Feb 5 2009, 03:27 PM
I've used a MSD for years and like it. Some will say they like them and some will not. I use a 6AL. It has an adjustable rpm chip slot. A chip kit for example goes from 6,000 to 7,000 in increments of 200 rpm. (6,000, 6,200, 6,400 and so on). It gets an incoming signal from the points or electronic pickup, depending on which dist. you have. Two wires go to the coil. It is easy to connect and mount. I mounted it in the engine compartment on my last 914-6. On my current project six, I'm mounting it behind the passenger's seat as seen in the pic. I would suggest if you use one that you match it with the MSD Blaster coil, use 7 or 8mm wires, and gap the plugs to 32-36 range. You may have to also use one of their tach adaptor. If you are using a points type dist., you may want to use a Petronix Ignitor or other electronic points replacing device. Thanks Dodger Im think`n i mite just try it....JT914-6.the distributer is stock but i do have 8mm wires and i think the coil is a blaster but not for sure I will check,behind the seat is out of the question it will have to be front trunk(long wires) or engine bay but i heard it has to be a relatively cool spot ..I dont have many options tough..plug gap is not a issue and does the tach wire hock up in the engine bay.I will have more info about the one i have on monday but the 6al # rings a bell thanks for your help Mike |
iamchappy |
Feb 5 2009, 03:34 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I've been using them since he 80's and have never had a problem.
jt914-6 |
Feb 5 2009, 03:43 PM
Mike,
I had the MSD box mounted in the engine compartment near the top so the fan would pull fresh air across it and never had a heat problem. The reason I mounted it behind the seat in the project is to unclutter the engine bay and have it in a cooler (temp) location. Just had to run pickup wires from dist. and two wires to the coil through the firewall. DO NOT mount it in the front trunk. There is no reason to. If anything, the rear trunk would be a second option to the engine bay mount. |
johnnie5 |
Feb 5 2009, 04:44 PM
914 lover Group: Members Posts: 375 Joined: 14-October 08 From: San Diego, CA Member No.: 9,644 Region Association: Southern California |
Mike, I had the MSD box mounted in the engine compartment near the top so the fan would pull fresh air across it and never had a heat problem. The reason I mounted it behind the seat in the project is to unclutter the engine bay and have it in a cooler (temp) location. Just had to run pickup wires from dist. and two wires to the coil through the firewall. DO NOT mount it in the front trunk. There is no reason to. If anything, the rear trunk would be a second option to the engine bay mount. I went with the rear trunk for mounting location Attached image(s) |
J P Stein |
Feb 5 2009, 05:39 PM
I use the MSD 6 al, MDS High Vibration coil, 8.5mm Magnecore wires, Petronix & NKG plugs gapped to .045. Bout 8 years now.....
The unit seems happy there on the right. Attached thumbnail(s) |
6freak |
Feb 6 2009, 09:30 AM
Both locations seem do`able for my car.The PO is coming over this Sunday to help me with pulling some trim pieces and the oil tank(go`n to the restoration shop)rear bumper and such..I will have him give me a hand with installing or at least get his point of view as well
other ideas welcome Thanks for everyones help Mike |
ConeDodger |
Feb 6 2009, 09:36 AM
I used the same mounting spot as Johnnie5 in the rear trunk against the engine bulkhead. I used a MSD6AL though. The limiting feature allows me to give the keys to my kid and let him drive it. I suspect with that 3000RPM limit he cannot get into too much trouble! (IMG:style_emoticons/default/laugh.gif)
6freak |
Feb 6 2009, 09:44 AM
I used the same mounting spot as Johnnie5 in the rear trunk against the engine bulkhead. I used a MSD6AL though. The limiting feature allows me to give the keys to my kid and let him drive it. I suspect with that 3000RPM limit he cannot get into too much trouble! (IMG:style_emoticons/default/laugh.gif) I do like that spot! looks clean ..but very little air flow if any.My car get pretty warm in the rear trunk! i take it you have not had any issues with it there.The only #`s i could read on my box are seriel#4101 and part#6240? maybe#6246 |
cobra94563 |
Feb 6 2009, 10:09 AM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
I had one give out.. but it was like 20+ years and on it's 3rd car.
BKLA |
Feb 6 2009, 10:41 AM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
Very happy with it, (but its new and only has , like, 20 minutes on it). I used the blaster coil and mounted both on the fire wall - oposite each other.
easy access! sorry 'bout the quality of the pic - its what I had here at the office... |
sixnotfour |
Feb 6 2009, 10:54 AM
914 Wizard Group: Members Posts: 10,437 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
What do you think you will gain over the stock CD box ?
How can you stand to modify your factory 914-6 ? This is your conscience speaking |
6freak |
Feb 6 2009, 11:22 AM
What do you think you will gain over the stock CD box ? How can you stand to modify your factory 914-6 ? This is your conscience speaking I dont really know what i will gain. (IMG:style_emoticons/default/confused24.gif) But i have this felling your going to tell me nothing.so i`m guess`n you would not do it..Maybe sell the thing to help offset the cost of the repair and paint ?I`m listening...Maybe i didnt make it clear to other folks that it was a factory 6 |
6freak |
Feb 6 2009, 01:23 PM
Very happy with it, (but its new and only has , like, 20 minutes on it). I used the blaster coil and mounted both on the fire wall - oposite each other. easy access! sorry 'bout the quality of the pic - its what I had here at the office... My coil is NOT a blaster if they all look like that .Mine is the round kind mounted on the fan shroud stock look`n but red |
charliew |
Feb 6 2009, 01:40 PM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
These engine bays are too pretty to be in running cars. If you guys drive these cars how much driving time versus cleaning time do you have. If it's like a harley it's 1 hour drive 4hours clean.
J P Stein |
Feb 6 2009, 01:50 PM
When I had a 2.4L T (carbed) motor in my car, it ran fine with the standard CD ignition.
That went away with the 2.7L hot rod motor. I could not get it to run right......after about 6 months of trying I went with the MSD set up and all was well with the world. I can see no advantage with the MSD unless you're having rough running/plug fouling. |
6freak |
Feb 6 2009, 02:06 PM
When I had a 2.4L T (carbed) motor in my car, it ran fine with the standard CD ignition. That went away with the 2.7L hot rod motor. I could not get it to run right......after about 6 months of trying I went with the MSD set up and all was well with the world. I can see no advantage with the MSD unless you're having rough running/plug fouling. runs rough when its cold (pop`n and cough`n)because no choke??right....warm it runs great and no plug fouling..... thanks JP Thats two people say`n dont go that route i think, starting to lean towards not doing it |
J P Stein |
Feb 6 2009, 02:20 PM
They all run shitty for the first minute or 2....or 5. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 13th June 2024 - 08:01 AM |
