Washer for ball joints?, Trying to locate a washer between ball joint and strut |
astronomerdave |
Feb 7 2009, 06:35 PM
Member Group: Members Posts: 69 Joined: 26-January 09 From: Los Angeles, CA Member No.: 9,979 Region Association: Southern California |
I'm replacing the ball joints on my '72 4 cyl. The original BJs had a washer on top, between the BJ and the strut. I ordered a new set from Pelican (901-341-049-00-M69) but it didn't come with any washer, nor is there one listed on their site. If you look at their full catalog then there isn't even a washer shown in the diagram. However, my Haynes manual shows the washer I removed (and damaged upon removal), as item 41 in Fig.7.2.
So, where can I find this washer if it's not listed at Pelican? What if I didn't use it? The ID of the washer that was there just fit snugly around the post of the BJ, so it might be tough to find a non-specific replacement. Thanks, Dave |
914Sixer |
Feb 7 2009, 08:08 PM
914 Guru Group: Members Posts: 8,902 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
As far as I remember it is just a common wave washer. Nothing special. Maybe someone else will reply and help us out here.
Cap'n Krusty |
Feb 7 2009, 09:39 PM
craig downs |
Feb 7 2009, 11:29 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Another one from So Cal (IMG:style_emoticons/default/welcome.png)
914Sixer |
Feb 8 2009, 07:57 AM
In book 4 of the factory manual on page 2.1-1.1 has the washer. On page 233 in the Lash repair manual it shows a flat washer. In the Haynes manual on page 100 it shows one. Page 75 of the Drake has one. Factory Parts book shows part # 901.341.659.00 (base)
astronomerdave |
Feb 10 2009, 11:26 AM
Glenn Sager at Pelican checked the Porsche parts software which says that washer was only used up through the 1972 model year and that it's no longer available.
By the way, it wasn't a standard washer, like from a hardware store; it's very thin (maybe 1 mm). |
Lo-Fi Version | Time is now: 6th June 2024 - 09:30 PM |
