POR and UV, what happens? |
BGman |
Feb 20 2004, 11:35 PM
Greg Group: Members Posts: 87 Joined: 18-January 04 From: Owensboro, KY Member No.: 1,575 Region Association: None |
POR warns that their product is not UV resistant and will discolor in the sun. Discolor? Is that all, or does it break down? I am considering finishing my engine bay right now with it. Is this area protected enough...or is it going to need to be topcoated. Car is garaged when not in use, and I don't use a raintray (which I suppose would help in this case). Thanks.
-g |
Evill Ed |
Feb 21 2004, 07:05 AM
Member Group: Members Posts: 238 Joined: 28-February 03 Member No.: 371 Region Association: None |
Yes, with the POR, it is mostly an asthetic issue. The resin appears to be safe, just the pigment fades.
The engine bay should have plentyl of protection from the direct sun and UV rays. Ed |
7391420 |
Feb 21 2004, 08:14 AM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
I used por 15 three years ago to re-paint my oil filler pipe on the back of my house.
-I'ts survived 2 summers out here without any noticable change |
aufaber |
Feb 21 2004, 02:16 PM
Member Group: Members Posts: 190 Joined: 7-April 03 From: Huntington Beach, CA Member No.: 525 |
If you use black.. nothing realy. if you use silver it turns kinda greenish yellow.
BGman |
Feb 21 2004, 05:34 PM
Thanks guys- just what I wanted to know. If you have used it outside and have seen little/any change then I am comfortable with it.
I really like the stuff, but boy do they have quite a system- 1. degreaser 2. metal prep 3. por 4. cover paint, or 5. "tie-coat" primer for aftermarket paint and then the aftermarket paint itself !!! ingenious. |
dmenche914 |
Feb 21 2004, 06:43 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Used POR silver paint to touch up my silver car exterior, in a few months it turned greenish silver, YUK. also used in engine bay, out of the sun, and no real change noticed after about a year.
good stuff, but top coat it if exposed to sun. dave |
Lo-Fi Version | Time is now: 3rd June 2024 - 07:52 AM |
