Fuel Starving?, Autoxing my car for the first time tomorrow |
Solo914 |
Feb 13 2009, 07:11 PM
Member Group: Members Posts: 266 Joined: 6-March 06 From: Redmond, WA Member No.: 5,678 Region Association: None |
Hello,
I have been autoxing for along time but this will be my first time really autoxing my 914. The car is a mostly stock 74 1.8, with konis and sticky street rubber and was wondering how much fuel I should run. I aligned it and took it for a spin and did some LONG sweeping turns and on a few of the turns I had fuel cut out. Now, I haven't been able to test LONG left hand turns yet but it is happening on the right hand cloverleafs. Even with a full tank I had it happen so I guess I am asking is if this is common? If it is common, are there any tricks besides a fuel cell or custom baffling a stock tank? If it isn't common, what would you be looking into? One thing I can think of is the Air Flow Meter(flapper door) closing under side loads. Kyle |
Joe Ricard |
Feb 13 2009, 07:31 PM
Not only should you worry about fuel starvation but also oil starvation as well.
I would run enough gas so the light does not go on in a hard turn. I can get the light on with WAY over 1/2 tank. However my carbs don't much care. |
SirAndy |
Feb 13 2009, 08:11 PM
Resident German Group: Admin Posts: 41,673 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Even with a full tank I had it happen No, it didn't ... Trust me, you can't put enough Gs on a stock 914 to starve the motor of fuel with a full tank. If your car was cutting out on hard cornering with a full tank, i suspect a lose electrical contact somewhere or maybe a clogged fuel filter (sucked in some crap from the bottom of the tank). I've driven many AX from stock 1.7 /4 to 3.6L /6 and i never ever had it cut out from fuel starvation. I usually start with about 1/2 a tank of gas and that lasts me all day. (IMG:style_emoticons/default/shades.gif) Andy |
Solo914 |
Feb 13 2009, 08:21 PM
Even with a full tank I had it happen No, it didn't ... Trust me, you can't put enough Gs on a stock 914 to starve the motor of fuel with a full tank. If your car was cutting out on hard cornering with a full tank, i suspect a lose electrical contact somewhere or maybe a clogged fuel filter (sucked in some crap from the bottom of the tank). I've driven many AX from stock 1.7 /4 to 3.6L /6 and i never ever had it cut out from fuel starvation. I usually start with about 1/2 a tank of gas and that lasts me all day. (IMG:style_emoticons/default/shades.gif) Andy I hear ya. Brand new fuel filter and recently cleaned tank so that is out. I think electrical connection or AFM. Kyle |
rhodyguy |
Feb 14 2009, 10:33 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i hope he didn't show up too low for today's event in bremerton. the mini-mart that was close to the track doesn't sell fuel any longer.
ConeDodger |
Feb 14 2009, 10:41 AM
Apex killer! Group: Members Posts: 23,609 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Hello, I have been autoxing for along time but this will be my first time really autoxing my 914. The car is a mostly stock 74 1.8, with konis and sticky street rubber and was wondering how much fuel I should run. I aligned it and took it for a spin and did some LONG sweeping turns and on a few of the turns I had fuel cut out. Now, I haven't been able to test LONG left hand turns yet but it is happening on the right hand cloverleafs. Even with a full tank I had it happen so I guess I am asking is if this is common? If it is common, are there any tricks besides a fuel cell or custom baffling a stock tank? If it isn't common, what would you be looking into? One thing I can think of is the Air Flow Meter(flapper door) closing under side loads. Kyle Impossible. You would have to turn the car upside down to actually starve it for fuel. L-Jet AFM have a couple of features that might be causing your problem. Some (later) have a fuel cut for roll over feature and you may be tripping that or you are just shutting your air flap door. You might try prying off the cover on the AFM and tightening the spring a little at a time. How is your EFI harness? You could be losing an electrical connection momentarily. |
Lo-Fi Version | Time is now: 5th June 2024 - 09:20 AM |
