Horn Base Plate, Where to get? |
Grelber |
Mar 5 2009, 05:20 PM
Insert favorite Don Rickles joke here. Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region |
While reinstalling my horn ring, I broke off the little tit on the base plate that the horn ground wire plugs into. According to George, AA is backordered on the plate until late April. Anyone know of another source, other than a WTB for a used one? (which I don't want if I don't have to). This is AA part # B914 613 805A.
A&PGirl |
Mar 5 2009, 05:30 PM
Senior Member Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None |
There is no other source.
Unless it is secretly a VW part or 911 part. Most used ones have the spade broken off and reapplied in a variety of interesting ways. If you still have the metal bit you, can solder it back on to the plate. If not you can take an electrical spade the same size and solder it on to the plate. You can even take a same size spade and rivet it back on to the plate. (using the correctly sized rivet of course) |
dr914@autoatlanta.com |
Mar 5 2009, 06:04 PM
914 Guru Group: Members Posts: 7,887 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
nope never made as a singular part. We had a backlog on producing them because of our great new 914 repair piece that is almost finished Yet the horn plates are soon
Dave_Darling |
Mar 5 2009, 10:48 PM
Cut out a small piece of sheet metal, solder it on. Works well, and so far has lasted me for 10 years.
--DD |
zeezee |
Mar 6 2009, 01:17 AM
Member Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California |
HCRDAN |
Mar 6 2009, 09:45 AM
Member Group: Members Posts: 113 Joined: 24-September 06 From: Austin, TX Member No.: 6,907 Region Association: None |
Same issue with mine. When I get around to it, I'm just going to cut a new tab into the metal using a dremel or wiresaw blade and gently bend the new tab to accept the ground wire. I think there is enough wire to reach the new tab.
I had a post last July about this exact same issue (Correction, not December as I stated in the Vday thread that will not die... (IMG:style_emoticons/default/barf.gif) ) and this was one of the options suggested. Given the other options, I think that is probably the most expedient manner. Others reported mixed results with soldering the errant tab back on, btw. |
Grelber |
Mar 6 2009, 12:42 PM
Same issue with mine. When I get around to it, I'm just going to cut a new tab into the metal using a dremel or wiresaw blade and gently bend the new tab to accept the ground wire. I think there is enough wire to reach the new tab. Others reported mixed results with soldering the errant tab back on, btw. Hadn't thought of just cutting a new tab. Thanks for the idea. |
A&PGirl |
Mar 6 2009, 02:36 PM
Soldering worked for me, but I had a lot of other issues too.
Lo-Fi Version | Time is now: 1st June 2024 - 05:09 PM |
