CARBON DEPOSIT REMOVAL CLEANERS?, I'VE TRIED EVERYTHING |
iamchappy |
Feb 25 2004, 07:30 AM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
I am trying to clean off the heavy carbon build up on the exhaust side of the turbocharger, I have tried brake cleaner, carb cleaner, gas, steam, sea foam, oven cleaner, aircraft paint remover, no luck, I have not tried liquid hydrogen or media blasting or chiminey creosote cleaner, any ideas on what will work without messing up the fragile turbine. (IMG:style_emoticons/default/confused24.gif)
Qarl |
Feb 25 2004, 08:19 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Have you tried MEK... it's a solvent you can get at Home Depot... Methyl Ethyl Ketone... not sure if it will work, but it's strong as sh*t!
thesey914 |
Feb 25 2004, 08:47 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
MEK is banned in England......something about being cacogenic (IMG:style_emoticons/default/wacko.gif)
used to be good for cleaning though! |
Qarl |
Feb 25 2004, 10:32 AM
Yes... wear gloves and a mask... or do it outside on a breezy day.
Don't smoke around it.... If you DO smoke, you may end up depositing your OWN carbon on it. |
RustyWa |
Feb 25 2004, 12:07 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
GM Top End Cleaner
Not sure of the part number but you can get it at your local Mr. Goodwrench. |
Thorshammer |
Feb 25 2004, 12:34 PM
Senior Member Group: Members Posts: 749 Joined: 11-November 03 Member No.: 1,335 |
Try your local Yamaha Motorcycle dealer, We use their carbon cleaner for decarbonization on motorcycle cylinder heads. They also have the very best carb cleaner (dunk style) chemical I have ever seen. You can brush it on crancases and they will look new.
Erik Madsen |
Lo-Fi Version | Time is now: 23rd May 2024 - 05:21 AM |
