Four for one deal, oil pressure? temp guage? nanaul? |
bicycleboy58 |
Mar 26 2009, 08:03 PM
Newbie Group: Members Posts: 20 Joined: 25-March 09 From: South Carolina Member No.: 10,201 Region Association: South East States |
What is the normal oil pressure reading for:
Warm engine at normal speeds? Warm engine at idle? Does Temp gauge indicate oil temp or cylinder head temp, and what is the normal operating temp in F or C? What is the preferred 914 repair manual? |
bicycleboy58 |
Mar 26 2009, 08:30 PM
r_towle |
Mar 26 2009, 08:35 PM
Custom Member Group: Members Posts: 24,594 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
What is the normal oil pressure reading for: Warm engine at normal speeds? Warm engine at idle? Does Temp gauge indicate oil temp or cylinder head temp, and what is the normal operating temp in F or C? What is the preferred 914 repair manual? Hi, Welcome to the club. 1----30-50 psi 2----20 or more oil temp on stock gauges. oil should be no more than 250 ish...that is hot. Haynes manual is pretty good, using search here is very helpful. A set of factory manuals is really the best... Rich |
type47 |
Mar 26 2009, 08:43 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
bicycleboy58 |
Mar 26 2009, 08:44 PM
What is the normal oil pressure reading for: Warm engine at normal speeds? Warm engine at idle? Does Temp gauge indicate oil temp or cylinder head temp, and what is the normal operating temp in F or C? What is the preferred 914 repair manual? Hi, Welcome to the club. 1----30-50 psi 2----20 or more oil temp on stock gauges. oil should be no more than 250 ish...that is hot. Haynes manual is pretty good, using search here is very helpful. A set of factory manuals is really the best... Rich Thank you very much. I tried to search for oil pressure but didnt come up with anything and my dad was pressuring me for an answer so thank you for the aid. He still wishes to know if the temp is from the cylinder head or oil. |
r_towle |
Mar 26 2009, 08:47 PM
oil temp.
If its all stock gauges (I would guess it is) There is no cylinder head temp gauge on these cars. Rich |
Dave_Darling |
Mar 26 2009, 08:53 PM
Rule of thumb for most cars:
You want at least 10 PSI per 1000 RPM with the engine warm. Up until the pressure relief valve opens, at least. The exact pressure depends on a lot of factors, from oil temp to oil pump condition to bearing clearances to oil viscosity... --DD |
Joe Owensby |
Mar 27 2009, 05:37 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
Where are you in SC? I live in Spartanburg. JoeO
Lo-Fi Version | Time is now: 17th June 2024 - 11:06 AM |
