Need clutch pedal shaft help, Possible to remove? |
biosurfer1 |
Apr 5 2009, 05:15 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
I tried to put my clutch back in today and ran into some problems.
While trying to put the clevis pin back in at the pedal, I found that the years of wear on the clutch pedal shaft built up some metal around the hole, so I can't get the clevis over the pedal. Is it possible to remove just the clutch pedal shaft, or do I have to remove the entire pedal cluster? The cluster worked good and everything looks good so I don't think it needs a complete rebuild, just a new clutch pedal shaft Any thoughts? |
ejm |
Apr 5 2009, 05:29 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,693 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The hole in the clutch arm that the clevis pin goes thru has a bushing. Was the OE plastic bushing so worn the arm itself got worn or is the problem with the bushing. The bronze pedal bushing kits come with this part.
biosurfer1 |
Apr 5 2009, 06:05 PM
No bushing at all...maybe that was my problem. I will try to take a picture of the old clevis pin, it was almost worn half way through.
I got a new clevis pin already, but it looks like I'll need a new clutch shaft too. |
ConeDodger |
Apr 5 2009, 07:55 PM
Apex killer! Group: Members Posts: 23,608 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
No bushing at all...maybe that was my problem. I will try to take a picture of the old clevis pin, it was almost worn half way through. I got a new clevis pin already, but it looks like I'll need a new clutch shaft too. Brett, Here is what you do. Drop your tools. Wash your hands. Get in your truck. Drive over here to my house. Pick up my spare rebuilt pedal cluster that I always keep on the shelf. Go home, put it in, drive it like you stole it. Send the existing one to Bruce Stone for rebuild and when it comes back bring it to me to go to my little spot on the shelf for the spare peddle cluster! (IMG:style_emoticons/default/biggrin.gif) |
biosurfer1 |
Apr 5 2009, 08:01 PM
I think I'll take you up on that Rob... I'll get a hold of you this week.
Thanks man:) |
ConeDodger |
Apr 5 2009, 08:05 PM
I think I'll take you up on that Rob... I'll get a hold of you this week. Thanks man:) De nada. You have always been there for me too... (IMG:style_emoticons/default/biggrin.gif) |
jeffdon |
Dec 11 2013, 10:51 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Someone needs to develop a simple puller for the damned clutch pedal to shaft connection. I am going into high heat, pickle fork mode tomorrow. What a bitch of a job.
jcd914 |
Dec 12 2013, 12:16 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I have done a bunch of these (not recently) and never had to use heat.
The cluster has to come out. Then support the clutch pedal at the base and drive out the roll pin. This is probably the hardest part since the base of the pedal is round. I usually clamp it in a vise but it is a little hard to get the right angle to drive out the roll pin. A good quality roll pin punch helps here. Then support the whole pedal cluster sideways, closely around the cable/clevis end of the clutch shaft. Clutch shaft needs to be vertical and clear of the support for the pedal cluster (the shaft has to have room to be driven out) Then using a big punch drive the clutch rod down and out of the clutch pedal. The key is good solid support around the pedal cluster where the clutch shaft comes out, then you can id it hard as needed to get the shaft to move. Jim |
PRS914-6 |
Dec 12 2013, 12:38 AM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
Lo-Fi Version | Time is now: 4th June 2024 - 10:47 AM |
