Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I've been asked by a few of of you to look into making these. The tooling is not inexpensive, but there apears to be a need to produce these. We're making some improvements, all the metal in the bumper will be stainless. We will also provide the nuts with nylon lock nuts. The rubber will be slighly harder. I will have the first samples in about 4-5 weeks. Production will be about 2 weeks after.
These sell at $335. Pictures of the parts will be posted as soon as they're ready. More pictures added on page 3 also. Attached thumbnail(s) ![]() ![]() Attached image(s) ![]() |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
I need a rear bumper top. Put me on the list.
Mikey914 |
Rear bumpers are still available, although not inexpensive. I may do those at some point in the future, but I thought that I'd start with what was not available, and make some improvements to the attachment that should make them last longer.
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
1 front bumper pad. Yes please put me on the list Mark.
914four |
Senior Member ![]() ![]() ![]() Group: Members Posts: 516 Joined: 4-March 07 From: Rainbow City, Alabama Member No.: 7,582 Region Association: South East States ![]() ![]() |
I would like one as well.
Kelvin |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,969 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Mike,
Your other rubber products are top notch from what we have seen so far...no doubt this will be too. Can you describe the details? I agree with you on the ethics of not producing a part that is still available OEM...that has a lot of integrity. I assume these will be molded and identical in dimensions? Why will the rubber need to be harder? Will the texture be like the original or smooth? What differences if any from the OEM part? |
kconway |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California ![]() |
Mike,
assuming the first production run is as spot on as your other products, I'm in. Put me in line. THANK YOU! (IMG:style_emoticons/default/beerchug.gif) Kev |
Mikey914 |
Mike, Your other rubber products are top notch from what we have seen so far...no doubt this will be too. Can you describe the details? I agree with you on the ethics of not producing a part that is still available OEM...that has a lot of integrity. I assume these will be molded and identical in dimensions? Why will the rubber need to be harder? Will the texture be like the original or smooth? What differences if any from the OEM part? These will be molded in identical dimensions, the hard part was finding a candidate that was in the correct dimensions to make identical to. Most of the samples I came across were warped, or split, which we could work with, but Craig had a pristine one he let me borrow. This helped speed up the process by not having to extrapolate what the shape should be. The rubber would not have to be harder, but it will not absorb water as readily, and would actually be more abrasion resistant. It's the texture will be like the OEM, not smooth and shinny like a fiberglass part. The idea is to keep it as close to OEM as possible making improvements where they make the most sense. To the observer the only way to tell the part is not OEM is that the mounting studs will not rust and the Porsche stamp will not be on the part. Some of the cavities on the bottom may be slightly different, but those will not be seen. Hope that answers some of the questions. |
t collins |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,270 Joined: 21-March 06 From: Virginia Member No.: 5,754 Region Association: None ![]() ![]() |
Please count me in for one!
Thanks, Tom |
okieflyr |
9fauxteen ![]() ![]() ![]() Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States ![]() |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
I've been asked by a few of of you to look into making these. The tooling is not inexpensive, but there apears to be a need to produce these. We're making some improvements, all the metal in the bumper will be stainless. We will also provide the nuts with nylon lock nuts. The rubber will be slighly harder. I will have the first samples in about 4-5 weeks. Production will be about 2 weeks after. These will sell at about $295, I will be offering a discount for those who want to line up for the production run. So, the real question is who needs these? They will be $265 for those of you put you name on the list now. After production begins they'll be available at the normal price. Pictures of the parts will be posted as soon as they're ready. Right now all I can do is say "Thanks." (IMG:style_emoticons/default/smilie_pokal.gif) |
my928s4 |
Member ![]() ![]() Group: Members Posts: 349 Joined: 18-August 07 From: Spokane, WA Member No.: 8,018 Region Association: Pacific Northwest ![]() |
Add me to the list, thanks !
Sleepin |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains ![]() |
Awesome! Please put me in for one!
Thank you for making these available again! |
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
I'm probably in for one....$ is tight, when will you need it?
Zimms |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,415 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest ![]() ![]() |
I'm in for 1.
Rotary'14 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 ![]() |
I want one too!
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,904 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Looks like the value of my NOS pad is going the direction of my bank stock!
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,245 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I don't need any, just wanted to say thanks for going through the trouble of making these!
(IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/beerchug.gif) Andy |
edrotol |
edrotol ![]() ![]() Group: Members Posts: 204 Joined: 23-April 06 From: Woburn, MA Member No.: 5,910 Region Association: North East States ![]() |
I've been asked by a few of of you to look into making these. The tooling is not inexpensive, but there apears to be a need to produce these. We're making some improvements, all the metal in the bumper will be stainless. We will also provide the nuts with nylon lock nuts. The rubber will be slighly harder. I will have the first samples in about 4-5 weeks. Production will be about 2 weeks after. These will sell at about $295, I will be offering a discount for those who want to line up for the production run. So, the real question is who needs these? They will be $265 for those of you put you name on the list now. After production begins they'll be available at the normal price. Pictures of the parts will be posted as soon as they're ready. Put me in for two (2) at the lower price. please. Thanks. |
Mikey914 |
I'm probably in for one....$ is tight, when will you need it? No cash will be accepted until the firts article is complete (and I'm satisfied) I'll post detailed pictures. Once were in production and I can Guarantee a shipping date, I'll start taking money. Right now you're in line in the order you posted. These will weigh about 8 lbs each + packing at another 6lbs. The packing may be a little more weight depending on how I wind up packing. Start saving you $$ you have a few weeks still. I apprecite your support. |
Lo-Fi Version | Time is now: 6th July 2025 - 08:03 PM |
