adjustable rear coilovers |
jmargush |
Apr 13 2009, 11:34 AM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am looking at Coleman racings threaded coilover kits. They have an I.D. of 2.040. When I measure my Koni Yellow sports I get 1.968 O.D. on the shock tube. Will their threaded sleeve be too loose? Does it need to be tight?
Also what length springs should I look for 10"? Any thing else I need to know when I make this purchase? |
J P Stein |
Apr 13 2009, 12:14 PM
I used .020 inch thick plastic shim stock wrapped around my 2.0 inch dia. Bils.....the yellow stuff on the bench. 10 inch springs in the pic.
BTW, the cable ties weren't strong enuff. Multiple wraps of safety wire did the trick. Had to do some backyard engineering to get the hats to fit around the flanged barrel nut. Attached thumbnail(s) |
jmargush |
Apr 13 2009, 12:57 PM
Jp,
Did you get yours through Coleman? They don't list Koni for the shock top and I am curious as to how close the Koni is to the Bilstein dimensionally. Jeff |
J P Stein |
Apr 13 2009, 01:11 PM
Yes, from Coleman.
The "top" (hat) actually fits onto the barrel nut which I believe is a standard 914 item.....but I have no experience with Konis. The shock top appears to be contained in the Colman kit....pg 111 of their catalog. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:53 AM |
