Clutch chatter, What causes it? |
mpoffers |
Apr 15 2009, 01:36 PM
Member Group: Members Posts: 52 Joined: 15-September 08 From: Portland, OR Member No.: 9,551 Region Association: Pacific Northwest |
My clutch can chatter pretty hard, particularly getting into first. I can get it to launch smoothly, I just have to be careful. It's a little easier to launch in second than in first.
My assumption is that a new clutch is in my future. I understand that this question is moot as I'll just replace everything, but what causes chatter? Is it warped friction surfaces? Bad surface finish? A slipping clutch makes sense to me, but I'm not sure I get what's going on in a chattering clutch. Thanks. |
southernmost914 |
Apr 15 2009, 01:45 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
Most likely warped flywheel surface but ,can be all of the above. (IMG:style_emoticons/default/bye1.gif)
Steve |
SirAndy |
Apr 15 2009, 03:09 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Oil on the clutch will make it chatter too ...
(IMG:style_emoticons/default/shades.gif) Andy |
sww914 |
Apr 15 2009, 03:31 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
Broken / loose motor mounts can cause it too. Not common but possible...
'73-914kid |
Apr 15 2009, 04:58 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
My dad had the same problem in his Vette. Chatter everytime he released the clutch. Turned out when we pulled everything apart to rebuild the tranny that the pressure plate was about 1/4 inch out of whack. Ordered a new plate, bolted it up, and no more chatter.
bryanf |
Apr 15 2009, 05:43 PM
Member Group: Members Posts: 105 Joined: 18-January 06 From: Half Moon Bay, CA Member No.: 5,435 |
improper clutch adjustment can cause chatter in my experience. Also a worn pivot for the T/O bearing can do it...
type2man |
Apr 15 2009, 07:57 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
The most common causes are broken motor mounts, a worn bowden tube, oil on the disc and a warped flywheel....
Lo-Fi Version | Time is now: 3rd June 2024 - 05:06 AM |
