Monday, 11 August 2025
> Lower tins, thermostat, Do you need them?
fitzm1
post Apr 21 2009, 07:06 PM
The consensus from the forum is that you must have the engine tins with the flaps installed and in the open position. It is also preferable to have the thermostat installed and working to get the engine up to temp. Does the thermostat work when the lower tins (air guides) are missing?
My thermostat works on the stove but doesn't seem to get hot enough to open when the engine is running.
How many of you have these lower tins installed?
Where can I get a set of these?
Thanks
Mike
Replies(1 - 4)
Joe Ricard
post Apr 21 2009, 07:57 PM
CUMONIWANNARACEU
You are talking about the warm air guides? I used to have them till I switched to the Tangerine EVO header.
I think you may not have something connected right. My bellows and flps still work correctly.
Katmanken
post Apr 21 2009, 08:24 PM
You haven't seen me if anybody asks...
Better have the ones that hug under the cylinders or you will be looking for a new engine...
fitzm1
post Apr 22 2009, 06:13 AM
Those are the ones. I'll check it again. Maybe I can find some at AA
QUOTE(Joe Ricard @ Apr 21 2009, 05:57 PM) *
Katmanken
post Apr 22 2009, 05:51 PM
Jake may sell them. If I recall correctly, he modifies type 1 under cylinder air guides.
- Lo-Fi Version Time is now: 10th August 2025 - 09:36 PM
