detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
I am curious if someone could say why i have a respectable amount of carbon build up on pistons 1 and 4 but not on 2 and 3? Is this a sighn of anything or style of runing condition.. ?? It is the first time i have seen my pistons since purchase last year any info is good info.
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Oil leaking past the rings?
detoxcowboy |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
FI or carbs?
detoxcowboy |
Katmanken |
Hard dry crusty carbon sounds like cooked oil.
Several causes. 1. bad valve guides leaking oil into the cylinder 2. oil rings didn't seat 3. score mark in the cylinder wall? (oil path) 4. Rings not staggered on the piston (all in a line on the bottom of the cylinder provides an oil path) Any smoke on startup or driving? |
r_towle |
It may also be that the injectors are not balanced properly..
Send them out to be rebuilt and balanced. Check your cold start injector and send that out also..they do drip and leak.. Rich |
detoxcowboy |
It may also be that the injectors are not balanced properly.. Send them out to be rebuilt and balanced. Check your cold start injector and send that out also..they do drip and leak.. Rich Thanks tOWLE.. ACTUALLY INSTALLED A NEW COLD START LAST WEEK AND JUST GOT MY INJECTORS BACK FROM SERVICE TODAY.. aLSO HAVE A NEW FI HARNESS TO BOOT .. I WAS LEANING THAT WAY.. |
r_towle |
did you hopefully re-ring the motor???
You might as well get new FI trigger points and clean and rebuild your distributor. Rich |
detoxcowboy |
did you hopefully re-ring the motor??? You might as well get new FI trigger points and clean and rebuild your distributor. Rich |
r_towle |
take a very focused, high resolution picture of the cylinders with the piston out, or all the way down. post it here.
Get rings from Jake..I think he sells hasting rings...they seal quickly. Rich |
detoxcowboy |
i can see cross hatching thats all i know.. nothing leaking and i did clean off all the carbon earlier today.. Attached thumbnail(s) ![]() |
detoxcowboy |
detoxcowboy |
r_towle |
When was this motor rebuilt? how many miles?
Your rings did not seat...but you still need to put in new rings. I cant really see those pics that well...they need better focus and each cylinder needs to be shown with the piston at the bottom of the stroke. Rich |
detoxcowboy |
When was this motor rebuilt? how many miles? Your rings did not seat...but you still need to put in new rings. I cant really see those pics that well...they need better focus and each cylinder needs to be shown with the piston at the bottom of the stroke. Rich cell phone camera is all i got.. so where do you recommedn i get rings?? supposedly rebuilt 6 0r 8 thousand miles ago, i have had the car a year and when it was rebuilt sometimes maybe year and 1/2 or 2years ago.. this car was not someones daily driver. how could you tell.. so iu know how to tell.. |
r_towle |
detoxcowboy |
Perfectly done towle.. why not.. nice lead they have orignal germans and 33% off too..
Todd Enlund |
Resident Photoshop Guru ![]() ![]() ![]() ![]() Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest ![]() |
Those are 2.0 bus pistons... are the rings the same? I'm not sure, but I seem to remember that bus rings are different than 914 rings.
Lo-Fi Version | Time is now: 31st July 2025 - 02:38 PM |
