budman5201 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 ![]() |
ALL 5 new syncros, 2 new sliders, adjusted per specs...... What are the symptoms of this rebuild? VERY Hard to shift at first? Its not in a running car yet, but mounted under it. It shifts VERY hard, will this get better as everything gets worn in? How long does that take?
Oh forgot to meantion, lubed up gears before install and shifted tough but fine through all gears on bench. But installed so far and tried it with no oil in tranny yet. I am assuming it will get a little easier with oil, but WOW it is stiff thanks for your advice (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/driving.gif) |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
It will get a lot better as soon as you use it a little bit. It feels worse with a short shifter if you have one.
HAM Inc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None ![]() |
Use Swepco gear lube and if your linkage is in good shape you'll have a great shifting 914!
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
You "lubed the gears"? What does that mean?
While we're at it, don't fall for the lure of the Swepco cult, unless you have some extra money you don't mind throwing away. Plain old GL5 will do the trick. Especially avoid ANY additive intended to make things "slicker", like MoSo2. The Cap'n |
budman5201 |
You "lubed the gears"? What does that mean? While we're at it, don't fall for the lure of the Swepco cult, unless you have some extra money you don't mind throwing away. Plain old GL5 will do the trick. Especially avoid ANY additive intended to make things "slicker", like MoSo2. The Cap'n Lubed the gears means I just put a little gear oil on them so when they were on my bench i could flip through the gears and make sure my adjustments were cool. I have Valvoline Gear synthetic oil is that cool? Oh no linkage, cableshift. It felt great before, i could litterally "feel"every worn dogtooth. Thats why i dove into it. I love it compared to stock. |
yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,455 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
No synthetic... Switch to cheap, dino oil or Swepco.
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
No swepco, no synthetic. Use cheap 90w GL5 and enjoy. The gears will shift hard at first. If you prelube, prelube the slider and synchro rings.
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
Yep- the rebuild the Doc did for me about 1 1/2 years ago was really stiff at first. I was worried. It sweetened up pretty soon- 6 weeks maybe, and is still nice and snappy now after at least 5000 miles. You want it to be like cold honey right now.
Red-Beard |
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None ![]() ![]() |
Dr Evil |
Ya, but you are rich (IMG:style_emoticons/default/KMA.gif) (IMG:style_emoticons/default/tongue.gif)
Red-Beard |
And someday, if you stop spending money rebuilding cars, you will be too! |
budman5201 |
And someday, if you stop spending money rebuilding cars, you will be too! I just used a spare transmission case and cut a hole out the side of it to ALIGN the gears again.(Clay Perrine trick on this site) This made the job "easy". I could literally see exactly if my forks were interfering with each other through all gear selections. . Once set. I pulled the stack out of my temporary case and WHA LA!!! Very nice shifting in my car now (by hand of course and stiff) I guess I didnt have the 4/5 gear fork set right. Now all of them are perfect. Thanks Dr. Evil for your advice. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 13th July 2025 - 07:00 PM |
