jt914-6 |
Driving & working on teeners 41 years ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States ![]() |
My banjo fittings and float valve covers are leaking fuel. I've used new gaskets, but still have leaks. Does anyone have any suggestions on fixing this? I've sanded the filter bodys with emery cloth and still leaks. Afraid to over tighten the banjo bolts. Would a suitable gasket compound be ok to seal these areas?
jt914-6 |
Found some fiber washers for the banjo's and some for the float covers. No leaks now. Have never had that problem before...........Thanks anyway.....
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
I have seen the banjo fittings crack before. Guess that's not your issue since you fixed it but the next time you may need to look there if you see fuel again.
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
If they get too bad, PMO does have an assembly that replaces the banjos, and has provisions for either push on or AN fittings for the fuel lines.
I've always had good luck with the gasket kits that PMO sells. |
jt914-6 |
The carbs aren't that old. I'll check for cracks in the future. I've contacted PMO about the replacement fuel kits, but haven't heard back from them.....am interested in them.
70Sixter |
Member ![]() ![]() Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States ![]() |
I noticed PMO is for sale according to an ad in Excellence or maybe Hemmings.
Maybe there is nobody answering the mail!? |
GeorgeRud |
Maybe Rich is getting tired! It was always best to fax him with your needs, then he would call you back when he could. Didn't waste as much time that way!
BTW, I didn't see one of his adds in the June Excellence! |
smdubovsky |
Member ![]() ![]() Group: Members Posts: 331 Joined: 27-September 04 From: Silver Spring, MD Member No.: 2,837 Region Association: MidAtlantic Region ![]() |
When I rebuilt my carbs I had a similar problem. Once the gaskets got wet and dried a few times they finally swelled/bonded to the metal and stopped. No leaking problems since.
Lo-Fi Version | Time is now: 31st July 2025 - 05:25 AM |
