| bryanf |
Apr 27 2009, 01:50 PM
Member ![]() ![]() Group: Members Posts: 105 Joined: 18-January 06 From: Half Moon Bay, CA Member No.: 5,435 |
I'm finally getting around to replacing the pushrod tube seals and I'm following the AA procedure using AA viton seals. Unfortunately when I try to seat the new seals by grabbing them with pliers and seating them, I need to grab the pushrod tubes with so much force that I'm denting and mutilating them in the process. It there a better way? Should I but hose clamps around them first?? Ideas?
The engine is in the car by the way... TIA Bryan |
| underthetire |
Apr 27 2009, 02:01 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
KY Not just for her pleasure.
| SLITS |
Apr 27 2009, 02:10 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Never had a problem seating them. I grab them with channel locks and hit the pliers in the handle area with the heel of my hand
, but .... Use a socket with a diameter that matches the od of the tube flange and "pop" it with a light blow from a hammer. |
| turboturtle |
Apr 27 2009, 02:12 PM
Member ![]() ![]() Group: Members Posts: 56 Joined: 19-February 09 From: Little Rock, Arkansas Member No.: 10,068 Region Association: None |
Scented n flavored not necessary unless......
A couple of mine look rough, but unless their collapsed, a little denting will not hurt. Your not expecting any visitors there, are you. If so you could spin them around to show the best side down. |
Lo-Fi Version | Time is now: 10th March 2026 - 08:37 AM |
