/6 Oil feedline size and pitch ... |
SirAndy |
Apr 29 2009, 12:36 PM
Resident German Group: Admin Posts: 41,673 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have what appears to be a factory /6 oil feedline from the tank to the motor. It's a large black hose with aluminum fittings on each end.
Does anyone know the size and thread pitch of the end that goes to the motor? I'm trying to find a short adapter to 12AN as i need to run some additional hose and my motor inlet has a 12AN fitting as well. (IMG:style_emoticons/default/idea.gif) Andy |
PRS914-6 |
Apr 29 2009, 12:41 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
I have what appears to be a factory /6 oil feedline from the tank to the motor. It's a large black hose with aluminum fittings on each end. Does anyone know the size and thread pitch of the end that goes to the motor? I'm trying to find a short adapter to 12AN as i need to run some additional hose and my motor inlet has a 12AN fitting as well. (IMG:style_emoticons/default/idea.gif) Andy Andy, Patrick Motorsports has a metric to AN adapter for that. I think B.A.T in Florida has them as well. Both ends.... |
SirAndy |
Apr 29 2009, 12:47 PM
Looks like this is it. 30mm to 12AN ...
http://www.patrickmotorsports.com/part/560/ (IMG:style_emoticons/default/thumb3d.gif) Andy Attached image(s) |
rudedude |
Senior Member Group: Members Posts: 510 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
Which one?
To the steel line at front or below the cooler? I can go measure mine in a few minutes. |
sixnotfour |
Apr 29 2009, 12:50 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
smart racing has em too;
http://www.smartracingproducts.com/engine.htm |
SirAndy |
Apr 29 2009, 12:51 PM
Which one? To the steel line at front or below the cooler? I can go measure mine in a few minutes. Well, my setup is a bit different. (IMG:style_emoticons/default/biggrin.gif) From the tank to the line next to where you have your oil cooler. On the drivers side. (IMG:style_emoticons/default/shades.gif) Andy |
rudedude |
Apr 29 2009, 01:09 PM
Mine is 30mm x 1.5mm
Jule |
SirAndy |
Apr 29 2009, 01:21 PM
IronHillRestorations |
Apr 29 2009, 08:23 PM
I. I. R. C. Group: Members Posts: 6,726 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You might also try Pegasus Racing.
jt914-6 |
Apr 29 2009, 08:54 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Andy, does your cooler look like this? You can see on it the adaptor I got from Pegasus. 30mm x 1.5mm female to 12an male. PN# 1219-12an. $38.99 in my last catalog.....
SirAndy |
Apr 29 2009, 09:29 PM
Andy, does your cooler look like this? Nope. The 3.6L does not have a engine mounted cooler. (IMG:style_emoticons/default/shades.gif) Andy |
jt914-6 |
Apr 29 2009, 10:03 PM
Like the one PRS914-6 posted? That would be a male 30 x 1.5mm to 12an. Pegasus's PN is 1218-12an. $28.99. Sorry, didn't know what engine you had...
SirAndy |
Apr 29 2009, 10:08 PM
Like the one PRS914-6 posted? That would be a male 30 x 1.5mm to 12an. Pegasus's PN is 1218-12an. $28.99. Sorry, didn't know what engine you had... Yes, sort of like in his pic, but i have a hard line on the engine that goes towards the front firewall and ends in a 12AN fitting. The hose from the Oiltank has a metric fitting. I'd like to get a short line (12AN) with a "T" for easy oilchange inbetween the two, hence my question about a adapter for the oil line end. It seems that either a 30mm to 12AN male or female will do as the "T" is available with both types of ends. (IMG:style_emoticons/default/thumb3d.gif) Andy |
Lo-Fi Version | Time is now: 5th June 2024 - 12:29 AM |
