WTB NICE Early NO vent Underdash pad, Got hotrod air A/c so no need for side vents anymore |
budman5201 |
May 6 2009, 05:28 PM
Senior Member Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 |
If you have a VERY nice underdash pad from an early car with no vents can i see a pic if you have one for sale? I am eliminating the vents on my side because i have a hotrod air underdash saver A/C heat unit
thanks guys Attached image(s) |
orange914 |
May 6 2009, 07:48 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
p.m. sent
mike |
zx-niner |
May 6 2009, 08:50 PM
Member Group: Members Posts: 294 Joined: 13-June 05 From: Las Vegas, NV Member No.: 4,269 Region Association: Central California |
Where do you get the heat? Water cooled engine?
budman5201 |
May 6 2009, 09:12 PM
yep subaru 2.0 turbo
charliew |
May 7 2009, 09:25 AM
Advanced Member Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
So are you going to use the cowl vent at all? Also is the shifter as good as those on the factory cable shift cars? honda, gm, mr2, so on?
budman5201 |
May 7 2009, 11:18 PM
So are you going to use the cowl vent at all? Also is the shifter as good as those on the factory cable shift cars? honda, gm, mr2, so on? The cableshift is great, only limitation is the 35 year old transmission. Mine has all new syncros and teeth,etc. But obviously its not as much as a gate like the mr2, etc due to the design of the transmission. Take the best shifting with all new bushings that you have stock and maybe a little better than that.... Nope welding the cowl shut in front no fresh air that way. |
koozy |
May 7 2009, 11:20 PM
Senior Member Group: Members Posts: 651 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
You still looking for the under dash pad? I'll dig mine out and take a photo if you are.
budman5201 |
May 8 2009, 07:16 PM
yeah still looking. Can you post a pic. Oh also do i need to redo the metal frame underneath or with some simple mods can it bolt up??
thanks |
Lo-Fi Version | Time is now: 12th June 2024 - 11:45 AM |
