Can the Type 4 engine run a fuel pump like a Type 1 engine? |
Cire |
May 6 2009, 08:15 PM
Member Group: Members Posts: 279 Joined: 12-March 09 From: Tucson, Arizona Member No.: 10,155 Region Association: None |
I have webers on my car. The fuel goes to a fuel pressure regulator and its at the correct fuel pressure for the webers. But I was wondering if you can put a mechanical fuel pump on the type 4 like you can with the VW. Where they made for that or strictly electronic fuel pump.
Eric |
underthetire |
May 6 2009, 08:26 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Yes you can. Have a bus 1.7 in the garage that had a mech fuel pump. But why would you want to ? (IMG:style_emoticons/default/unsure.gif)
McMark |
May 6 2009, 08:46 PM
Only a relatively few engines are set up for mechanical fuel pumps. The boss for the pump is near the flywheel, on the bottom, on the 1 & 2 side. If your case wasn't set up from the factory, you're out of luck.
So if you insist on it, you need to search for a motor that was set up that way at the factory. Then you can build that motor into any displacement/setup you want. Of course, I wouldn't run a 'built' motor on a mechanical setup. Long story, short: use an electric pump. Especially since the 914 is set up to use one from the factory. |
underthetire |
May 6 2009, 09:15 PM
Only a relatively few engines are set up for mechanical fuel pumps. The boss for the pump is near the flywheel, on the bottom, on the 1 & 2 side. If your case wasn't set up from the factory, you're out of luck. So if you insist on it, you need to search for a motor that was set up that way at the factory. Then you can build that motor into any displacement/setup you want. Of course, I wouldn't run a 'built' motor on a mechanical setup. Long story, short: use an electric pump. Especially since the 914 is set up to use one from the factory. Hey McMark, does that mean the 1.7 I have is worth like....ONE MILLION DOLLARS... (IMG:style_emoticons/default/drooley.gif) |
VaccaRabite |
May 7 2009, 04:07 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
SURE! Just have to find someone willing to pay. Zach |
Lo-Fi Version | Time is now: 3rd June 2024 - 06:37 AM |
