tps positioning blocks.. mounting? |
detoxcowboy |
May 9 2009, 10:34 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
where do the tps postioning blocks (small rubber wedge) mount inside the switch?
Cevan |
May 10 2009, 08:47 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Is mine missing something? There's no rubber wedge in mine.
detoxcowboy |
May 10 2009, 10:02 AM
I do not see it in your picture, it does not seem to affect performance but? I opened my TPS and found a rubber wedge with a slot in it loose inside.. Pictured Below.. It is very small 1/2 the size of a dime.. Here is what I read which led me to believe it is supposed to be in there but where I do not know? How important is it? I was just hoping someone else has the experience to know where it is supposed to mount inside the TPS before closing it up..
you must open the throttle switch - be careful, there are some rubber positioning blocks that may fall out. [quote] |
JeffBowlsby |
May 10 2009, 05:12 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
You got my interest piqued...does this photo answer it for you?
Attached thumbnail(s) |
SirAndy |
May 10 2009, 05:14 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You got my interest piqued...does this photo answer it for you? Yeah, i had those fall out on mine back in the day. They go into the corners on the cover ... (IMG:style_emoticons/default/shades.gif) Andy |
detoxcowboy |
May 10 2009, 06:06 PM
You got my interest piqued...does this photo answer it for you? that's them!! In the upper corners of the cover!! I just had the other one fall out this morning.. Now that I see them I feel better they are not serious.. Thanks Jeff!! You were dead right on the Tps setting at 1 hash below switch point.. Basically the ECU needs a signal of 1 ohm to suggest idle. I chased that Ohm.. I have tried it at the zero Ohm setting or on the edge which is still O Ohm and the only way it will even hold an idle regularly without the input is to advance the timing on the distributor.. and the richness on the ecu.. .. Also at the zero mark or switchpoint the calibration setting inside the TPS will allow the ECU will miss 1 trigger point/ pulse (signal) on acceleration richness pulses. stupid demon taught me about the djet dance, I adjusted and readjusted every component checking vacum measurement etc.. 1 ohm lesson.. Your FI harness by the way cleared up a bouncy tachmoter.. I should have bought your harness instead of anything first.. |
JeffBowlsby |
May 10 2009, 09:15 PM
Your FI harness by the way cleared up a bouncy tachmoter.. I should have bought your harness instead of anything first.. Cool! Glad it helped. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 02:56 PM |
