bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
When rotors are redrilled to 5 hole rotors, do you use studs inside out or normal wheel screw in lugs?
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
You will use studs from the inside. They are available in a variety of lengths if you are going to be using any wheel spacers.
Mr.C |
Easy does it ![]() ![]() ![]() Group: Members Posts: 612 Joined: 31-December 02 From: Central Cal Member No.: 61 Region Association: None ![]() |
So does anybody know of a good source? I need to do this along with some spacers.
kconway |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California ![]() |
So does anybody know of a good source? I need to do this along with some spacers. Paragon Products http://www.paragon-products.com/SearchResu...sp?Search=studs |
Lo-Fi Version | Time is now: 4th July 2025 - 06:26 AM |
