replacing fuel pump |
scoobykvn |
May 10 2009, 09:36 AM
Member Group: Members Posts: 142 Joined: 6-July 06 From: columbus, ohio Member No.: 6,388 Region Association: Upper MidWest |
I just got a 1970 1.7 liter stock engine that I am putting in my 914 for temporary use. The car had a 2.0 liter carb'd that I am now rebuilding. My question is what type of fuel pump do I need to use ? Can I just get any fuel pump that supplies at least 28 psi? Is there anything else I should know about swapping a 1.7 injected for a 2.0 carb'd?
Joe Bob |
May 10 2009, 10:21 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Low pressure rotary style....3-5 psi. The 1.7 is a fuel injected pump and is high pressure.
Also, some people use the return line and others don't. Personal preference. You might want to consider an inline pressure regulator and a sight glass style fuel filter. |
scoobykvn |
May 10 2009, 10:42 AM
The engine going in is fuel injected, stock 1.7. Don't I need a high pressure pump for that? I am removing the carb'd engine.
Joe Bob |
May 10 2009, 11:00 AM
Guess I need to read slower...yes, you need an FI pump, proper fuel lines, a return to the tank line and high pressure fuel filter.
When you rebuild the 2.0...get a proper cam for the carbs. The FI cam, if still in there, is not optimal. |
silverteener |
May 10 2009, 09:53 PM
Member Group: Members Posts: 214 Joined: 9-August 05 From: East Moline, IL Member No.: 4,566 |
You will need a 3 port pump. I recently got for only 75.00 used. They are out there. good luck (IMG:style_emoticons/default/beerchug.gif)
Cap'n Krusty |
May 10 2009, 10:55 PM
You will need a 3 port pump. I recently got for only 75.00 used. They are out there. good luck (IMG:style_emoticons/default/beerchug.gif) Not true. You can use a 2 port pump such as was used on '75-'76 914s and a whole slew of L-jet VWs. Less than half the price, requires minimal plumbing mods. You still need the return line .................. The Cap'n |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:17 AM |
