Yet another breather routing question, Carb set up - does this look good? |
neil30076 |
May 11 2009, 05:58 PM
Recovering dismantler! Group: Members Posts: 397 Joined: 12-September 06 From: San Diego ( RB) CA Member No.: 6,826 Region Association: Southwest Region |
I did not think about it until now, but on my 1.7 ish dual carb set up - does this vent/vapor lines setup look good? This is how it was when i got the car but engine has been cleaned up a lot since then :-)
Attached thumbnail(s) |
SirAndy |
May 11 2009, 07:36 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
nycchef |
May 11 2009, 07:50 PM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
I did not think about it until now, but on my 1.7 ish dual carb set up - does this vent/vapor lines setup look good? This is how it was when i got the car but engine has been cleaned up a lot since then :-) niel, i left my charcoal filter system unattached. is it necessary for the engine or is this a calirornia emmisions requirement? i know they are tougher out there than here. |
Cap'n Krusty |
May 12 2009, 07:55 AM
I did not think about it until now, but on my 1.7 ish dual carb set up - does this vent/vapor lines setup look good? This is how it was when i got the car but engine has been cleaned up a lot since then :-) niel, i left my charcoal filter system unattached. is it necessary for the engine or is this a calirornia emmisions requirement? i know they are tougher out there than here. There's NO reason to leave it off/loose. It's a passive system, preventing much of the raw fuel vapor from the tank from escaping into the atmosphere. Be a good guy, hook it up. One of the immediate advantages to you is a reduction in the raw gas smell in the passenger compartment. The Cap'n |
nycchef |
May 12 2009, 08:33 AM
QUOTE There's NO reason to leave it off/loose. It's a passive system, preventing much of the raw fuel vapor from the tank from escaping into the atmosphere. Be a good guy, hook it up. One of the immediate advantages to you is a reduction in the raw gas smell in the passenger compartment. The Cap'n will do cap"n.. have the nipple on the driver side and the 2 tubes running along the fire wall, also a sort of female connection on the pass side of the fan housing . what goes where? neil sorry for hijacking your thread (IMG:style_emoticons/default/flag.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 09:50 PM |
