Question and Research- Factory Service Manuals |
stutghaus |
May 12 2009, 01:23 PM
Newbie Group: Members Posts: 2 Joined: 22-April 09 From: Mooresville, NC Member No.: 10,289 Region Association: South East States |
If someone on the forum has an original, known complete set of hard copy Factory Service Manuals( FSM's) for the 914/914-6 please check something for me. I have two sets of FSM's. One is a photocopy of a friend's set, which he said was complete. Another set is not a photocopy, but the set of binders and actual pages from a factory set. Here's the dilema. Both sets list Sections 1 and and 3 in the front index for Group 3 Transmission. Sections 1 and 3 deal with the manual 5-speed transmission. Both of my sets do not include Sections 1 and 3, but go on to show extensive Sportomatic info as advertised in the Index. Do you have Sections 1 (1.1 and 1.2) and 3 (actually 3.1) in your complete hard copy original, complete set containing Group 3 Transmission?
If I check my microfiche version of the FSM's, it includes Sections 1 and 3. I am questioning whether it is a coincidence that both of my sets just happen to be missing these sections or did Porsche not include these with the hard copy version thinking that the Technician would/could use the 911 VOL I and II Group 3 FSM that deals with the 901 transmission. Porsche did in fact follow similar logic with some other FSM's. The 911 Volumes for the 72-83 911 were sold separate from Vols I and II, which were for the earlier 911's. Porsche advised that you needed both the early set ( Vols. I and II) to go along with the subsequent 911 set. The 944 FSM's state the the 924 FSM's should be referred to for much of the body related info. Please shed some light on this issue. Bill |
krazykonrad |
May 12 2009, 06:40 PM
Senior Member Group: Members Posts: 1,128 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Sorry not to be of help. I'm sure there is someone on the board who's up on this.
Konrad |
rwjames |
May 12 2009, 08:00 PM
Member Group: Members Posts: 326 Joined: 2-June 06 From: Montgomery, AL Member No.: 6,136 Region Association: South East States |
I have two sets of factory shop manuals. Both copywrite dated 1969.
-One set has binders that are red outside with gray vinyl on the inside and aluminum circular rings around the hole on the spine. -One set has binders that are red on the outside and inside and no aluminum rings around the holes in the spine. Bot sets have sections 1 and 3. I sounds like you are missing a couple sections. |
stutghaus |
May 12 2009, 08:16 PM
I have two sets of factory shop manuals. Both copywrite dated 1969. -One set has binders that are red outside with gray vinyl on the inside and aluminum circular rings around the hole on the spine. -One set has binders that are red on the outside and inside and no aluminum rings around the holes in the spine. Bot sets have sections 1 and 3. I sounds like you are missing a couple sections. Thanks for your help. Bill |
Max914 |
May 12 2009, 09:11 PM
Newbie Group: Members Posts: 11 Joined: 4-August 04 From: Austin, TX Member No.: 2,453 Region Association: None |
I have a set in gray binders purchased from PP a little less than a year ago.
I am also missing section 1 but I do have section 3. |
Katmanken |
May 13 2009, 09:16 AM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Index in my manuals is different from the section pages.
Looks like they redid the organization of the manual, and eliminated some sections. The info is there, but it is now in either section 3 (manual) or section 4(sporto) which seems to make more sense than the indexes bouncing around from manual to sporto to manual to sporto to manual to sporto. For example, manual tranny removal is now in the manual tranny section 3, rather than in another section. |
Lo-Fi Version | Time is now: 8th June 2024 - 12:07 AM |
