Any pics of 16x6 911 Fuchs on 914's |
barada |
May 17 2009, 02:41 PM
Member Group: Members Posts: 257 Joined: 5-October 08 From: Atlanta Member No.: 9,613 Region Association: None |
Anyone running these on their 914? I wanted 7's but it seems like it takes some magic to get them to fit in the rear, therefore I think I want to go the easy route of 6's albeit at a higher cost probably.
Thanks Phillip ps I will break out of the newbie stage soon enough. |
ScooterD |
May 17 2009, 03:10 PM
ScooterD Group: Members Posts: 80 Joined: 6-August 06 From: Los Altos, CA. Member No.: 6,589 Region Association: None |
The rotors are stock 4 cylinder versions that were drilled and studs were installed.
Anyone running these on their 914? I wanted 7's but it seems like it takes some magic to get them to fit in the rear, therefore I think I want to go the easy route of 6's albeit at a higher cost probably. Thanks Phillip ps I will break out of the newbie stage soon enough. |
Jeffs9146 |
May 17 2009, 03:16 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Here are the ones on my old car!
Attached image(s) |
barada |
May 17 2009, 04:52 PM
The rotors are stock 4 cylinder versions that were drilled and studs were installed. Anyone running these on their 914? I wanted 7's but it seems like it takes some magic to get them to fit in the rear, therefore I think I want to go the easy route of 6's albeit at a higher cost probably. Thanks Phillip ps I will break out of the newbie stage soon enough. Looks great what size tires? |
ConeDodger |
May 17 2009, 05:04 PM
Apex killer! Group: Members Posts: 23,596 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
205 50 16 tires (I don't care about no stinking speedometer! Can't see it anyway)
Attached image(s) |
ScooterD |
May 17 2009, 05:13 PM
Porsche Rescue |
May 17 2009, 05:41 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
6x16, 205/55
Porsche Rescue |
May 17 2009, 05:42 PM
6x16, 205/55
Edit: now that I think about it, these are 7's with 205/45's. Sorry. Did have to stretch the rear fenders a bit. |
pete-stevers |
May 17 2009, 06:56 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
yup those are sevens
drgchapman |
May 18 2009, 05:24 PM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
oops
drgchapman |
May 18 2009, 05:56 PM
Here are some 16x6 Boxter wheels F/R on my DD with 195/50/16 Khumo Ecsta's courtesy of Porsche Rescue, got my monies worth out of these Jim! Just received, after a considerable wait time, some Harvey Weideman reconditioned 16x6 Fuchs in the boxes, finished like 15's. Going on soon.
These wheels/tires for sale, $500. |
drgchapman |
May 18 2009, 06:01 PM
barada |
May 20 2009, 07:06 PM
Michael N |
May 21 2009, 12:53 AM
Certifiable Group: Members Posts: 1,426 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
JFJ914 |
May 21 2009, 09:02 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Here are some 16x6 Boxter wheels F/R on my DD with 195/50/16 Khumo Ecsta's courtesy of Porsche Rescue, got my monies worth out of these Jim! Just received, after a considerable wait time, some Harvey Weideman reconditioned 16x6 Fuchs in the boxes, finished like 15's. Going on soon. These wheels/tires for sale, $500. Did you need spacers w/ the Boxter 6" wheels? |
drgchapman |
May 21 2009, 09:08 AM
Backspacing same as 911, no spacers needed.
mskala |
May 21 2009, 11:03 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
16x6 Boxster wheel offset is 50mm, not the same 6" fuchs (36mm). IMO ~35mm is the best offset for getting wheels centered on the rear, you could use about a half-inch spacer.
I once test-fitted 6x15 phone dial (52mm) and it rubbed on the inside. |
drgchapman |
May 21 2009, 11:07 AM
16x6 Boxster wheel offset is 50mm, not the same 6" fuchs (36mm). IMO ~35mm is the best offset for getting wheels centered on the rear, you could use about a half-inch spacer. I once test-fitted 6x15 phone dial (52mm) and it rubbed on the inside. You may be right, but they fit perfectly, no spacers, no rub, no fender mods. Easy-smeezy. |
mskala |
May 21 2009, 12:01 PM
16x6 Boxster wheel offset is 50mm, not the same 6" fuchs (36mm). IMO ~35mm is the best offset for getting wheels centered on the rear, you could use about a half-inch spacer. I once test-fitted 6x15 phone dial (52mm) and it rubbed on the inside. You may be right, but they fit perfectly, no spacers, no rub, no fender mods. Easy-smeezy. 195/50 are not very wide. I think the random tire I had was 205/60 (stockish diameter). |
barada |
May 21 2009, 09:11 PM
Lo-Fi Version | Time is now: 23rd May 2024 - 06:19 AM |
