My Tranny Drank a 40oz last night, oh my |
jsayre914 |
May 18 2009, 12:05 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
Not that kinda tranny (IMG:style_emoticons/default/biggrin.gif)
I adjusted the clutch last night at the fork, and figured since i was there pulled the top fill plug on the tranny to top her off. I went through an entire bottle and then some (IMG:style_emoticons/default/blink.gif) befor it was full. (IMG:style_emoticons/default/WTF.gif) keep in mind that this is my daily driver, and it was full one month ago. The bottom of my car is always wet, thats nothing new, but somthing must be wrong right?? I filled it lastnight with lucas 90 and drove into work today. I will monitor the level closly where does the fluid usually run out on the tranny? i noticed the speedo angle drive is connected to another metal ring that seems to be kinda loose. But it was not leaking that i could see. (IMG:style_emoticons/default/confused24.gif) how much fluid does the tranny hold anyway? |
Ferg |
May 18 2009, 12:19 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
Sideshift?
If so do you have the plastic cover? Remove that and see if it's full of oil. Ferg |
jhadler |
May 18 2009, 12:56 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Was the car level when you filled it? If the car was no flat and level, then you may have just overfilled it. It's happened...
-Josh2 |
jsayre914 |
May 18 2009, 02:26 PM
Yes its a sideshift, i will look under the plastic cover tommorow, and check for a swimming pool.
The car was level when i filled it last night. mabey my car was just thirsty (IMG:style_emoticons/default/beer3.gif) |
904svo |
May 18 2009, 05:17 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
I just had to replace my clutch. When I pull it out it was covered in a light
coat of oil. The inside of the transmission was also wet with oil, what I found was the clutch ball ( ball joint that screws into the transmission that holds the fork) was not tight!!! Trans oil was leaking past it getting inside the trans then leaking on the clutch plate causing my clutch to slip also the lose ball was causing me to adjust the clutch a lot. I reinstalled it with blue locktite now my clutch don't give me any problems now. I also had to refill my transmission also. |
Lo-Fi Version | Time is now: 7th June 2024 - 01:35 PM |
