another "just my luck" thread, this is easily #8 |
lotus_65 |
May 21 2009, 09:10 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
so i'm pulling the bad engine mounts from my farm-field engine chappy and i installed a couple weeks ago...
(don't even ask why i didn't swap them when it was on the stand) (IMG:style_emoticons/default/051103-stupid4.gif) the cross bar is loose hanging on the clutch cable (ok) shift bar's out and i've gotten the passenger side one out. drivers side is clogged with gunk, so i go for the bracket like i did the other one. i start cranking on the top bolt with the ratchet and become concerned just as i realize i've loosened the bolt enough to tighten the back of the ratchet snug against the fan housing. now i can't get to the dial on the ratchet to reverse my path to free the wrench. the socket's too slippery to turn with a channel lock, but i'll try to get after it with a needle nose vise grip. i don't know about you, but i'm pretty sure i'm too stupid to own this car. (IMG:style_emoticons/default/051103-stupid4.gif) (IMG:style_emoticons/default/051103-stupid4.gif) (IMG:style_emoticons/default/051103-stupid4.gif) (IMG:style_emoticons/default/051103-stupid4.gif) (IMG:style_emoticons/default/051103-stupid4.gif) (IMG:style_emoticons/default/051103-stupid4.gif) l8r thefleur |
iamchappy |
May 21 2009, 09:33 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
so i'm pulling the bad engine mounts from my farm-field engine chappy and i installed a couple weeks ago... (don't even ask why i didn't swap them when it was on the stand) (IMG:style_emoticons/default/051103-stupid4.gif) the cross bar is loose hanging on the clutch cable (ok) shift bar's out and i've gotten the passenger side one out. drivers side is clogged with gunk, so i go for the bracket like i did the other one. i start cranking on the top bolt with the ratchet and become concerned just as i realize i've loosened the bolt enough to tighten the back of the ratchet snug against the fan housing. now i can't get to the dial on the ratchet to reverse my path to free the wrench. the socket's too slippery to turn with a channel lock, but i'll try to get after it with a needle nose vise grip. i don't know about you, but i'm pretty sure i'm too stupid to own this car. (IMG:style_emoticons/default/051103-stupid4.gif) (IMG:style_emoticons/default/051103-stupid4.gif) (IMG:style_emoticons/default/051103-stupid4.gif) (IMG:style_emoticons/default/051103-stupid4.gif) (IMG:style_emoticons/default/051103-stupid4.gif) (IMG:style_emoticons/default/051103-stupid4.gif) l8r thefleur Not supid, just a monkeys uncle (IMG:style_emoticons/default/huh.gif) Hit it with a hammer and duck..... |
lotus_65 |
May 21 2009, 11:49 PM
sorta like that.
finished, now going to testerout. |
lotus_65 |
May 21 2009, 11:50 PM
... i am THE dunkle
Lo-Fi Version | Time is now: 3rd June 2024 - 01:32 AM |
