upgraded ignition wire troubles, Bosch to Clewett |
zeezee |
May 22 2009, 09:19 PM
Member Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California |
I've had Bosch ignition wires for a year. And the car has always started and ran on first crank. I just upgraded the wires to Clewett spiral core. It seemed fine for a couple days. But now it's a real pain to start and keep running until warm (backfires and floods easily). Once warm - no problems.
Could there be a connection? Why did I upgrade? Because the Clewetts are yellow! +5 hp!! Actually, I have a MSD with rev limiter that never worked right because of RF interferance. The spiral core wires fixed most of the RF problems. MSD rev limiter works most of the time now. I'm considering going back to Bosch and or disconnecting the MSD. Edit: Sorry, not RFI but EMI |
Joe Ricard |
May 23 2009, 09:50 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Are these the kind of wires with american connector? Are you sure you are feeling the click when the boot is going on the plug?
Obviously you put the screw on tips back on your plugs. are they tight? |
zeezee |
May 23 2009, 10:29 AM
Are these the kind of wires with american connector? Are you sure you are feeling the click when the boot is going on the plug? Obviously you put the screw on tips back on your plugs. are they tight? This wire set (made for 914) has the same non-tip plug connectors as the Bosch. They all snap on tightly. |
Cap'n Krusty |
May 23 2009, 10:50 AM
REAL men don't let other men use Bosch plug wires. They are, shall we say, "downmarket". There are others out there that are far better. FWIW, I've never had problems with Clewitt's wires.
The Cap'n |
zeezee |
May 23 2009, 11:47 AM
zeezee |
May 27 2009, 12:57 PM
I disconnected the MSD. It is acting "normal" now. Starts right up and same power as before.
I suspect that the previous Beru solid core wires were essentually disabiling the MSD with excess EMI. And when I replaced them with the spiral cores the MSD started "working" for the first time since I had the car. Maybe the MSD is not working properly. More testing is needed. |
Kirmizi |
May 27 2009, 01:08 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
I seem to recall reading something in the MSD owners manual about not using solid-core wires. When I installed my MSD, I also replaced the plug wires with a set of Clewetts and haven't had any problems.
Mike |
Lo-Fi Version | Time is now: 23rd May 2024 - 10:38 AM |
