Best spark plugs for 1.7 ? |
orange73 |
Jun 8 2009, 10:25 AM
orange 72 Group: Members Posts: 14 Joined: 11-May 09 From: Homer Glen IL. Member No.: 10,355 Region Association: Upper MidWest |
I need new plugs for the 72 1.7 eng. , whats the plugs most people have best luck with ? There are Bosch super RO 971 in now.
Cap'n Krusty |
Jun 8 2009, 11:08 AM
That's not a part number. The number is stamped into the metal, not printed on the ceramic. You should be using NGK B6ES (7432) or Bosch W7CC (7998). With carbs, you should probably run one heat range hotter. The Cap'n
dlo914 |
Jun 8 2009, 12:50 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
That's not a part number. The number is stamped into the metal, not printed on the ceramic. You should be using NGK B6ES (7432) or Bosch W7CC (7998). With carbs, you should probably run one heat range hotter. The Cap'n (IMG:style_emoticons/default/agree.gif) with the NGK B6ES. |
orange73 |
Jun 8 2009, 03:51 PM
That's not a part number. The number is stamped into the metal, not printed on the ceramic. You should be using NGK B6ES (7432) or Bosch W7CC (7998). With carbs, you should probably run one heat range hotter. The Cap'n Thanks and yes the stamped number is w7cc, I do have dual Webers carbs, so how do i know one heat range hotter ? |
zeezee |
Jun 9 2009, 01:00 AM
Member Group: Members Posts: 115 Joined: 16-October 08 From: san ramon, ca Member No.: 9,651 Region Association: Northern California |
http://www.ngksparkplugs.com/techinfo/spar...&country=US
Sounds like I should go +1 hotter too - good to know! |
orange73 |
Jun 13 2009, 01:05 PM
That's not a part number. The number is stamped into the metal, not printed on the ceramic. You should be using NGK B6ES (7432) or Bosch W7CC (7998). With carbs, you should probably run one heat range hotter. The Cap'n Hello Cap'n , I have the 72, 914 with the 1.7 eng. and dual webers. you suggested the hotter plug W8CC - 7904 I am having a heck of a time finding here in IL. tried NAPA , Autozone etc. is that a Bosch plug? any suggestions or websit to find that plug ? Thanks Dan |
Cap'n Krusty |
Jun 13 2009, 03:08 PM
Yes, it's a Bosch plug. The equivalent NGK is B5ES, 6410. Chain stores only carry stuff they can easily sell in large volume.
The Cap'n |
smg914 |
Jun 13 2009, 10:15 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
I have 60 NOS Bosch W7C and 50 NOS Bosch W8C spark plugs. Most of them are in their original packaging of 10 plugs per box. I would be willing to open the boxes and sell them in groups of 4 plugs for $10.00 shipped.
Lo-Fi Version | Time is now: 10th June 2024 - 10:13 PM |
