tying up some loose ends, wires actually |
nycchef |
Jun 8 2009, 07:57 PM
mechanical moron Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
have a few loose wires on my catrbed 2.0.need to know where they go.
(1).brown wire in lower pic 1 is from the taco plate. where do i hook this up to? (2) green and red wire is from relay board. wheres a proper place for him (3) pic 3, is this the cylinder head temp sensor? do i need it on a carbed engine? if so what wire ..well you know thanks in advance Attached image(s) |
ws91420 |
Jun 8 2009, 08:12 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
pic 3 is for the oil pressure light
nycchef |
Jun 8 2009, 08:21 PM
jt914-6 |
Jun 8 2009, 08:44 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Yes, the green/red wire connects to the oil pressure switch in pic # 3.....
nycchef |
Jun 8 2009, 08:56 PM
Yes, the green/red wire connects to the oil pressure switch in pic # 3..... thanks one down one to go (IMG:style_emoticons/default/smilie_pokal.gif) |
jt914-6 |
Jun 9 2009, 06:21 AM
A solid brown wire is usually a ground wire.....
Dave_Darling |
Jun 9 2009, 08:49 AM
If it's coming out of the taco plate, it's not the ground wire. Could be a replacement wire, or could be oil-stained. Though I wouldn't think a green/black wire would stain to brown...
Find a green/black wire in the main wiring harness. The end of it will be under the battery tray or in that area. There should be a one-wire box connector on the end of it. The green/black wire from the taco plate plugs into that, which goes to the oil temp gauge. If your car has never had the gauge, the connector might not be on the end of the wire, and the wire may be wrapped up in the harness. If your car is a 70-72, the wire probably isn't there and you will have to add it. --DD |
nycchef |
Jun 9 2009, 09:59 AM
If it's coming out of the taco plate, it's not the ground wire. Could be a replacement wire, or could be oil-stained. Though I wouldn't think a green/black wire would stain to brown... Find a green/black wire in the main wiring harness. The end of it will be under the battery tray or in that area. There should be a one-wire box connector on the end of it. The green/black wire from the taco plate plugs into that, which goes to the oil temp gauge. If your car has never had the gauge, the connector might not be on the end of the wire, and the wire may be wrapped up in the harness. If your car is a 70-72, the wire probably isn't there and you will have to add it. --DD my bad it,s got a very brittle brown casing over it, it's actually green, will try to find it.s mate by tracing from the center console harness back. that still leaves a white wire with a long plactic box connector on it, leftover from the f.i ? |
nycchef |
Jun 9 2009, 02:16 PM
[Find a green/black wire in the main wiring harness. The end of it will be under the battery tray or in that area. There should be a one-wire box connector on the end of it. The green/black wire from the taco plate plugs into that, which goes to the oil temp gauge.
found it, thanks dave |
Lo-Fi Version | Time is now: 11th June 2024 - 09:50 PM |
