fixing stuff, aaaaaa |
jea69 |
Jun 13 2009, 05:47 PM
doing unspeakable things to iron Group: Members Posts: 51 Joined: 13-March 08 From: norway Member No.: 8,811 Region Association: Scandinavia |
rant. sitting with the trottlebody on my workbench , with the valve closed i can
allmost walk thru it , no wonder the idle been high (IMG:style_emoticons/default/dry.gif) , its riveted on top of the thru axel for good measure, im a blacksmith i know riveting, ha! , guess im hammering/filing the valve flap to fit the ovality of the t body bore . whatever happened to replacable parts. (IMG:style_emoticons/default/dry.gif) |
VaccaRabite |
Jun 14 2009, 07:38 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
P.Rocket |
Jun 15 2009, 06:16 AM
Member Group: Members Posts: 54 Joined: 17-March 08 From: Abbotsford BC Member No.: 8,822 Region Association: None |
rant. sitting with the trottlebody on my workbench , with the valve closed i can allmost walk thru it , no wonder the idle been high (IMG:style_emoticons/default/dry.gif) , its riveted on top of the thru axel for good measure, im a blacksmith i know riveting, ha! , guess im hammering/filing the valve flap to fit the ovality of the t body bore . whatever happened to replacable parts. (IMG:style_emoticons/default/dry.gif) My idle used to hang up and was very slow to come down at a stop. I ran a small tap thru the air bleed hole on the throttle flap and installed a small machine screw. The throttle returns to idle perfect and bangs down nicely between shifts. Very sweet fix. And the screw can be removed if it doesn't work for you. Good luck! |
jea69 |
Jun 15 2009, 02:29 PM
rant. sitting with the trottlebody on my workbench , with the valve closed i can allmost walk thru it , no wonder the idle been high How high was your idle? Zach hi, it would never go lower than 1500, that was after fixing the aar valve. before that 2000 . the trottlebody is pretty worn ,so i hammered out the edges of the valve stretching the metal to close the gaps and make it a perfect fit to the imperfect bore . now i can allmost kill it with the air screw all in (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 08:37 PM |
