Engine won't idle after a good run |
Ian Stott |
Jun 14 2009, 11:46 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
Went for a little run this morning and temps got up to point the needle was straight up and down on the oil temp gauge, first time ever that high of a reading and it is a warm day, engine sounding great and running smooth, get to the stop sign at the end of the down ramp and engine stalls! Restarting with no problem off I go and get to the next stop sign about 500 meters and engine dies again, rstarts and runs fine but will not idle! What has happened??!
Ian Stott Moncton Canada |
tradisrad |
Jun 14 2009, 12:37 PM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
is your aux air valve controlling your idle air 'cause it's always open and now that the engine is hot it is closed? just a thought. try the idle screw
cwpeden |
Jun 14 2009, 03:31 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
I think it might be Canadian air. I'm having the same prob
Ian Stott |
Jun 14 2009, 05:23 PM
I'm sure it isn't too serious as it ran soooooooo good, smooth power and no hiccups at all, it was early Sunday morning with no traffic; so yes it was a high speed run but on a divided highway with no traffic, I passed no one. Anyway enough justification of the speeding, approximately 9 minutes of 100 MPH plus, then slowing normally to the stop sign at the end of the off ramp, temp gauge reading right in the middle where it has never been before (and I have read here previously that gauge and it's info is basically useless) and engine stalls, starts up again with no problem but stalls again at next stop sign which is approx. 500 meters. Engine still runs smooth with good power like before but will not idle, it stalls! Any thoughts on what has happened much appreciated and needed!
Ian Stott |
Ian Stott |
Jun 16 2009, 07:52 AM
So it starts up for me this morning and is running a bit rough but stays running, get to the on ramp of the Trans Canada and wow does it ever accelerate, runs very nice with good smooth power. So I'm thinking ok it was just something that happens when it is quite hot, drive about 5 KM at about 70 MPH and no burps or hiccups, just smooth with nice power, I must have burned all the carbon out of it I'm thinking, but then it dies at the stop sign, it restarts but not easily. Any engine guru's out there with thoughts or suggestions??
tradisrad |
Jun 16 2009, 08:28 AM
do you have FI or carbs? did you try the idle screw (if you've got FI)?
jamie74 |
Jun 16 2009, 08:48 AM
Newbie Group: Members Posts: 6 Joined: 5-June 09 From: Toronto Member No.: 10,437 Region Association: None |
fuel filter?
Jeffs9146 |
Jun 16 2009, 09:34 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE do you have FI or carbs? Yes, if it is FI check the CHT Sensor! |
Ian Stott |
Jun 16 2009, 11:32 AM
Yes it is stock FI, 1973 2.0. I will check the CHT sensor, give me a hint on how to check it!
Ian Stott |
underthetire |
Jun 16 2009, 12:17 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
it's just a variable resistor. Check with an ohm meter to ground. Make sure you check it HOT and cold. Mine was fine until it got hot then went open. Took me a while to find.
tod914 |
Jun 16 2009, 12:58 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Once it's warm, try capping off the Aux. air reg and see if it idles better. Sometimes they don't close all the way.
Ian Stott |
Jun 17 2009, 10:09 AM
I am in the process of parts identification, when I get that down pat I will start playing with adjustments and cleaning! Big week here, middle daughter graduating from High School, prom, picture taking, relatives arriving, extra groceries to get etc. it's all good not complaining! Will get back to my 914 problem this weekend I hope. Thanks for all the advice.
Ian Stott |
banger |
Jun 17 2009, 11:41 AM
Member Group: Members Posts: 354 Joined: 12-November 06 From: Santa Clarita Member No.: 7,205 Region Association: Southern California |
When I bought my car, I had a similar problem. It turned out that one of the plastic hoses from the charcoal canister in the front, was connected to the plenum instead of the air cleaner. When you would decelerate on the off ramp, it would pull a vacuum on the tank, and the engine would not get fuel.
Katmanken |
Jun 17 2009, 01:44 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Hmmm..
Fuel pump still making noise??? Pulling a vacuum in the tank might make the pump work harder and noiser for less output... |
Lo-Fi Version | Time is now: 1st June 2024 - 06:46 AM |
