Question about subaru motor sensor, Got broken off before I got the engine, with pic |
malaga_red75 |
Jun 16 2009, 02:43 PM
'74 2.5L N/A Subie Group: Members Posts: 454 Joined: 5-March 06 From: Menlo Park, CA Member No.: 5,674 Region Association: None |
Here is is...this is located on top of the engine right next to the crankshaft position sensor. This is the one that had the blade style connection on it.
First pic, shows the location. and second shows better detail, kinda sorry for the blurry pic. but its just a blade style connection that looks like it was cut and twisted with some vice grips Also, what is this sensor? Mass Air Flow? here's a link to my progress thread... http://www.914world.com/bbs2/index.php?sho...c=85845&hl= |
malaga_red75 |
Jun 16 2009, 02:57 PM
Forgot to say that it is a 1996 EJ25.
Skunkwrx |
Jun 16 2009, 03:35 PM
Newbie Group: Members Posts: 2 Joined: 18-May 09 From: Las Vegas Member No.: 10,375 Region Association: Southwest Region |
Pic #1&2 are oil pressure switch.
Pic #3 Idle Air Control |
malaga_red75 |
Jun 16 2009, 04:39 PM
malaga_red75 |
Jun 16 2009, 05:33 PM
Also, what is the difference between the ignitor and the coil? I am confused as to what needs to be on the engine. Right now there is a coil pack with 4 leads coming off of it which goes directly to each plug. and a connector from the harness.
VOX |
Jun 16 2009, 10:24 PM
Member Group: Members Posts: 129 Joined: 6-February 09 From: rosemead, ca Member No.: 10,027 Region Association: None |
since i'll be doing this soon, i hope you get some good responses, and if you can please keep track of what your doing! hopefully tony gets his schematics up sometime soon.
strawman |
Jun 17 2009, 12:30 AM
Senior Member Group: Members Posts: 881 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California |
Also, what is the difference between the ignitor and the coil? I am confused as to what needs to be on the engine. Right now there is a coil pack with 4 leads coming off of it which goes directly to each plug. and a connector from the harness. You should really consider picking up factory-based manual to check out the component and wiring diagrams. I bought mine on-line; just do a Google search on "1996 Subaru Legacy". The Haynes manual is pretty crappy, but it can be used in a pinch to locate components using the wiring diagams. Geoff |
Lo-Fi Version | Time is now: 6th June 2024 - 12:58 PM |
