ruddyboys |
Hummel eigentümer ![]() ![]() ![]() Group: Members Posts: 595 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States ![]() |
I have a 74 with a 70 1.7 bigbore. I have SS HE's for a 70 1.7 and 74 2.0. I (IMG:style_emoticons/default/wavey.gif) need to get a new muffler so which HE would be the better choice.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
2.0 liter...
Larger interior dimension of tubing. Rich |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
plus more options with regards to muffler sytems.
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) Your motor will love (IMG:style_emoticons/default/wub.gif) you. Welcome to the board.
LvSteveH |
I put the Poor in Porsche ![]() ![]() ![]() Group: Members Posts: 1,080 Joined: 22-April 03 From: Las Vegas, Nevada Member No.: 600 ![]() |
I agree, the 2.0L would probably have more muffler options, but I believe the tubing size is the same on the SSI exchangers for both the 2.0 and 1.7/1.8, which makes sense. If you are going to make an aftermarket part, why not build it to the highest flow. Maybe Brad can confirm.
Rgreen914 |
Member ![]() ![]() Group: Members Posts: 285 Joined: 20-October 03 From: West Covina, Ca. Member No.: 1,266 ![]() |
Brad told me the 2.0 H.E.'s would "really wake up a 1.7"; unsure if he meant "stock" H.E.'s or stainless H.E.'s.
garyh |
Member ![]() ![]() Group: Members Posts: 170 Joined: 8-January 03 From: San Mateo, CA Member No.: 114 ![]() |
QUOTE(LvSteveH @ Mar 4 2004, 09:35 PM) I believe the tubing size is the same on the SSI exchangers for both the 2.0 and 1.7/1.8, which makes sense. That's what I remember too. (I'm not brave enough to mention SSI in front of Brad.) The Bursh muffler is essentially the same for the 1.7 and 2.0. IMHO, the 1.7 is nicer because it sits up higher. Muffler hangers are probably easier to get for the 1.7 setup. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The aftermarket exchangers have the same diameter--so there is very little difference between the 1.7 and the 2.0 versions, pretty much just the "kick-up" near the end. That will likely make some small difference, but not a lot.
The stock 2.0 exchangers are smaller diameter than the aftermarket ones, and the stock 1.7 ones are smaller yet. So the aftermarket bits should help out over the stock 1.7 bits. The stock 1.7 muffler hanger should indeed be easieir to get, so if you don't already have a 2.0 muffler hanger that may be a factor. Then again, the 1.7 exchangers are pretty uncommon so you may be able to sell them for decent $$ and buy or make a 2.0 hanger.... --DD |
ruddyboys |
I have both HEs and hangers for the 1.7 and 2.0. I like the idea that the 1.7 wil pushe the muffler up out of the way alittle more.
Lo-Fi Version | Time is now: 4th July 2025 - 04:55 PM |
