I musta pissed someone off, cause it just aint goin right....got the alt. out, replaced FI hoses |
cwpeden |
Jun 16 2009, 08:12 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
All in one day,
Wheel bearing Fuel leaks Charging system Trunk lock (IMG:style_emoticons/default/WTF.gif) Where do I start (IMG:style_emoticons/default/blink.gif) I dont know, just looking for a little sympathy I guess. I'll get started after my boys Little League game and groceries. Man I love being domestic (IMG:style_emoticons/default/screwy.gif) |
RJMII |
Jun 16 2009, 08:14 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
I feel your pain... I own a 914 also. =o)
markb |
Jun 16 2009, 08:18 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
URY914 |
Jun 16 2009, 08:25 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,883 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Welcome to the club, I mean world.
Gint |
Jun 16 2009, 10:21 PM
Mike Ginter Group: Admin Posts: 16,076 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Wait until you open the engine lid to top up the oil and either see daylight out the hellhole or the battery is laying on top of the motor.
Such is life with a classic car. (IMG:style_emoticons/default/beerchug.gif) |
sww914 |
Jun 16 2009, 11:08 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
At least people smile and wave and want to talk about cars when they see you driving a 914. Doesn't happen in a Camry.
Gint |
Jun 17 2009, 06:52 AM
Nothing like driving in to work at 05:30 in the summer with the top off already too.
It could be worse! |
cwpeden |
Jun 20 2009, 02:24 PM
Well I took the Alt. out today.
Heres a picture list of the items to remove to make it easy. And the hole left: Once all the parts are out the alternator practically falls out till you disconnect the wires (IMG:style_emoticons/default/dry.gif) |
stepuptotheMike |
Jun 20 2009, 03:43 PM
medium pimpin Group: Members Posts: 565 Joined: 4-September 06 From: Charlotte, NC Member No.: 6,769 Region Association: South East States |
You know what.... I think you just helped me solve the problem with my engine tin with your last picture. I've had a gap in mine since I had my alternator rebuilt a few weeks ago..... back out to the garage to fix it. Good luck with yours. I was a pain in the arse that took me many hours, but at least now I know how to do it.
Mike |
cwpeden |
Jun 21 2009, 12:49 PM
Mke, What was your dilema?
Replacement Alt. went in ok. There has to be an easier way to get the bottom bolt in....Its in and the alternator is good. Turned out to be the reg. I guess. Replaceed all the FI hoses in the engine compartment. I used 5/16 and it was pretty painless. Except for the gas getting in the cuts from doing the alternator. Note to self...torque wheels before test drive (IMG:style_emoticons/default/slap.gif) Next step will be CV's and wheel bearings. |
PanelBilly |
Jun 21 2009, 12:59 PM
914 Guru Group: Members Posts: 5,810 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
The regulator I GUESS?? Aren't you sure?
I had an altenator problem. I took it out and put it back over and over tring to figure out what was going on. Would charge sometimes and not others. On the bench it would test fine. I'd test other things and they'd be fine too. Kept comming back to the alternator. FInely, I pulled it apart and saw that one of the brushes was split in half. That's why it worked sometimes and not others. |
cwpeden |
Jun 21 2009, 01:11 PM
Ya, same thing here.
Took out bench test fine put back in , no good. Back out, took to a proper auto-electrical shop, bench tested fine at all revs. Hooked up reg at auto-electrical shop no good/intermittent. Took shitty old dirty reg off the shelf works ok. I'm no electrical guru....things turn and electrons move, thats about it from my perspective. I borrowed an alt from a buddy and my original is in the shop for a rebrush anyways they said that these alts. break brushes and they bounce when short. So better safe than sorry. |
stepuptotheMike |
Jun 21 2009, 02:09 PM
Mke, What was your dilema? Replacement Alt. went in ok. There has to be an easier way to get the bottom bolt in....Its in and the alternator is good. Turned out to be the reg. I guess. Replaceed all the FI hoses in the engine compartment. I used 5/16 and it was pretty painless. Except for the gas getting in the cuts from doing the alternator. Note to self...torque wheels before test drive (IMG:style_emoticons/default/slap.gif) Next step will be CV's and wheel bearings. I had got the bugger back in and bolted up, but I couldn't get the bottom piece of engine tin to line up correctly. Had a big arse gap at the bottom of the fan. Went back out to the garage last night after looking at your picture and was able to get it tapped in the correct way, so all's good now. Mike |
r_towle |
Jun 21 2009, 02:15 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
The regulator I GUESS?? Aren't you sure? I had an altenator problem. I took it out and put it back over and over tring to figure out what was going on. Would charge sometimes and not others. On the bench it would test fine. I'd test other things and they'd be fine too. Kept comming back to the alternator. And you figured, while you had the alternator out....you might as well paint the engine bay....and then...while you were there... Look how that turned out...huh Rich |
Lo-Fi Version | Time is now: 29th May 2024 - 05:12 AM |
