FS: 75 semi prepared, 2056 engine |
richardL |
Jun 17 2009, 06:33 PM
Senior Member Group: Members Posts: 713 Joined: 27-January 03 From: San Diego, CA Member No.: 201 Region Association: None |
Motor: Fat Performance 1.7 built to a 2.0 with 96mm pistons and 71mm crank (2056), lightened flywheel. Tuna Can, aluminum valve covers. Hard tranny mounts.
A regular transmission is currently installed, a transmission with the differential welded for zero slip is in the package or available separately (not sure of the ratios in that transmission). Weber 40mm IDEs. 4/1 Header and Dynomax muffler. Complete remote oil cooler and accessories Very Solid 1975 chassis #4752904308 Chassis Stiffening Kit Installed Complete front oil cooler setup Fresh halfshafts and CVs New cables Car is fully stripped of excess weight Fiberglass bumpers No side glass Driver's side window net 2 new 5 Point Harnesses Racing Drivers seat + Momo seat External power cut-off switch Bolted down roof (can be unbolted with two bolts/nuts) Safety clipped windshield (widnshield has a crack) Volt, Pressure, and Temperature gauges Momo Prototipo steering wheel Yokohama A008R 195/50/15 tires in very good condition Class legal stock brakes with racing pads and fluid Rear tow hook Front tow bracket available The car had a 6 point roll hoop, that has been removed. Car has been re-wired and all electrical parts work (including horn, wipers, lights etc.) Also a second full (carbed) 2.0 engine, condition unknown, but it rotates. Misc. wheels and tires (good Kuhmos) PM me with questions. Detail Pictures (49MB): http://www.linsdall.com/914pics.zip This is in San Carlos, near Redwood City, SF Bay Area, CA - $4000 obo |
Gint |
Jun 17 2009, 07:22 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Would you like me to "move" your original post now Richard?
richardL |
Jun 18 2009, 10:16 AM
richardL |
Jul 13 2009, 10:01 AM
Bump
I would like to see this gone...make me an offer! |
Lo-Fi Version | Time is now: 10th June 2024 - 03:50 AM |
